DIY - Transgo VB Kit
Old Feb 22, 2010 | 04:59 PM
OCG35's Avatar
says DIY and there's no DIY?
Old Feb 22, 2010 | 07:48 PM
Tollboothwilley's Avatar
Originally Posted by officerdbag
God............................... I want this like so bad... After the gears and nitrous I guess
Yes, yes you do want this
Originally Posted by tiguy99
Hell yeah! I should be getting mine this week too! Look for my DIY review sometime early next week
Next up...3.3 VLSD
TB, what are some of the difference between both kits if you don't mind me asking? Also how's the ride and drive between both year Gs? Do they both have neck snapping shifts like some people describe? Is one vb better than the other one?
Ride is the same between both. The first time you put it in gear you notice...for SURE. No more laziness between R to D when shifting. You'll jerk the car. Just putting it in gear your whole car will jolt.
Normal driving it is not obtrusive. Noticeable, but puts a smile on my face.
Hard driving, well, thats just fun.
edited first post. had to get pics off my camera...camera batt was dead
Old Feb 22, 2010 | 08:15 PM
OCG35's Avatar
nice & congrats I'm not to keen on the "jolt from R to D" though
also, your 1st post update makes mention 06 coupe, tcu inside... but says 03-04.5 are different... 04.5 tcu is inside too (thats went they went inside)...
Unless you mean something else about it is different?
Old Feb 22, 2010 | 08:27 PM
oh... ya, i guess 04.5 - now are all different with the TCU inside. Your VB would look like the pictures
Its only a jolt into gear when the fluid temp isn't warmed up completely yet. Its not a bad thing...just gotta make sure you are sliding backwards from R and throw it in D without coming to a complete stop to avoid that huge jolt
Old Feb 23, 2010 | 12:45 PM
Its not bad. Its just a firm/quick change in motion. When fluid is very cold its more firm, but under normal conditions its not bad. Its not very noticeable during typical driving....its only when you are WOT that the shifts are very noticeable. Trust me when I say that this is a very good thing.
ALL 5AT should have this if you drive hard or ever track your car.
Old Feb 23, 2010 | 12:51 PM
As for the difference between the two version of the VB
this is the 04.5-newer VB
this is the 03-04 (notice the blue connectors). newer version just has wire connector from top side to bottom side.
03-04 are slightly easier to get out of the vehicle because the connectors all unclip from below. 04.5+ you have to unclip some from the top.
Old Feb 23, 2010 | 01:49 PM
ntrinsik's Avatar
I want..
Old Feb 23, 2010 | 03:28 PM
TofuProductions's Avatar
I'm getting mine installed tomorrow. I'll post up info about it as soon as tomorrow evening comes by.
Old Feb 23, 2010 | 06:34 PM
superchargedg's Avatar
This probably is the best mod i have done(with the exception of the twins)and the shift speed is incredible and def needed if boosted.Around town driving you can feel it but it is not annoying or harsh in anyway...but get on it and watch out.
Since i have the twins i can spin the 1-2 and the 2-3 shift and can also chirp 4th easily and even n/a you will still feel the explosive shifts.Its a friggen blast to drive in mm with this kit.
Old Feb 23, 2010 | 07:17 PM
Yes, all true! It does take a little getting used to such fast shifts though. LOL
One time it scared me cuz I wasn't expecting it. So used to the slow shifts of the past. haha
Mike, send me your VB and a kit and I'll do it for ya cheap
Old Feb 23, 2010 | 07:56 PM
MikeGrote's Avatar
I helped out tollbooth and own the 06 that we did. I would say it def helped to have 2 sets of hands for this job. could be done by one, but two people made it easier. very, very messy but well worth the instant gear changes!
Old Feb 23, 2010 | 08:30 PM
Brwn5454's Avatar
I've installed the Transgo and Edge Racing high stall torque converter on my car and I say after you've installed the Transgo kit fill it up with Redline D4 ATF. (My opinion.)
Unless you are still under warranty...which will be voided on the trans anyway with the Transgo kit...
Old Feb 23, 2010 | 08:46 PM
MikeGrote's Avatar
whats wrong with matic-s?
Old Feb 23, 2010 | 08:50 PM
Brwn5454's Avatar
Nothing wrong with it.
If you look around to those with FI and AT's most of them choose to go with Redline D4 as most believe it keeps things cooler and allows for colder weather smooth shifts.
I ran S-matic for 35,000 miles and had nothing wrong with it, don't get me wrong. I switched to Redline D4 when I put in my high stall torque converter and love the new feel.
Do what you are most comfortable with!
Old Feb 23, 2010 | 08:55 PM
  #30
MikeGrote's Avatar
gotcha, i have a trans cooler so it should stay plenty cool with that for what power i have right now
