Problem with Flywheel timing...
Old May 30, 2010 | 01:42 PM
06g35meister's Avatar
Short: Anyone that has done a JWT flywheel, how do i time it?
Long: So i replaced the clutch on my car and the flywheel had to be taken off for a new friction plate (JWT setup). Now i did not know that the car had a timing sensor on the flywheel so i put the car back together and it would not start... no spark. Turns out the timing on the flywheel was off. SO now i get to take it all back apart and adjust to the correct timing. Luckily i was able to unplug the sensor and the car will still drive... for the time being. So i need to know anyone that has done a JWT flywheel, how do i time it?
Old May 30, 2010 | 02:09 PM
Manual G's Avatar
I think your supposed to put the flywheel in the same position it was in when it was taken off. Thats what I did when I changed my clutch. The sensor your talking about is the crankshaft position sensor. Hopefully someone with more knowledge can chime in. I would like to know more about this myself.
Old May 30, 2010 | 02:36 PM
That would be the idea, but i did not mark the flywheel when i took it out, so i have no idea where it was, ive tried 2 positions lining the keyhole up with the pointy thing on the crankshaft, but the timing is still off as the engine is cutting spark.
Old Jun 1, 2010 | 05:20 PM
bump
magnetism80
Feb 1, 2019 10:00 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
wuzz-upp
Oct 3, 2015 04:21 PM
mattdg35
Sep 14, 2015 11:28 AM
Jnm07
Sep 5, 2015 01:16 AM
