clutch problem? help, engine revs when i get on the gas
Old Jun 7, 2010 | 12:06 PM
fluxcap's Avatar
Hello, i have a 2006 G35, it recently started doing this:
when driving and Im around 3.5k or 4k rpm, clutch is fully depressed, and i get on the gas, the engine will rev up 1.5k or 2k rpm on top with no power and then after a couple of seconds will drop down and start speeding up.
what could be causing this? clutch?, fluid?, cylinders?
thanks!
Old Jun 7, 2010 | 12:33 PM
jwolfpk's Avatar
im no expert but it sounds like your clutch is slipping..you probably need a new one..
Old Jun 7, 2010 | 02:09 PM
kvangil's Avatar
Time for a new clutch. It's slipping.
Old Jun 7, 2010 | 02:46 PM
fluxcap's Avatar
fair enough, so what am i looking at to replace the clutch? are there options or is there a standard g35 replacement?
how much do you guys think the shop will charge me?
Old Jun 8, 2010 | 08:00 PM
fluxcap's Avatar
Thanks guys just talked to the shop, can you guys give your input on the quote????
here is the new thread:
https://g35driver.com/forums/drivetr...ml#post5155681
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
wonderizm
Sep 24, 2015 03:09 AM
derres
Aug 28, 2015 03:27 PM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
