Auto Trans Fluid Check
Old Aug 22, 2010 | 12:16 PM
Maciuniu's Avatar
Hello guys.
Yesterday i have decided to change my ATX fluid. I have done as a lot of you statded , as in drain the fluid measure exactly and put what you have taken out. Well after dooing so i figutrred let me check the level. Transmision hot engine running on a level ground. What i have noticed is that the disp stick i showing way over level. Is that possible or i am reading or dooing something wrong. Btw the fluid seems to be reaching first curved area on the stick, way above 2 grooves and above x'd out area. Please Help
Mark.
Old Aug 23, 2010 | 12:06 PM
rcdash's Avatar
The level on the dipstick is directly related to the temperature of the fluid. If you don't know the temp, you won't know the correct level. With a cold engine, let her idle 10 mins and then do a cold reading.
Old Aug 23, 2010 | 04:44 PM
Tollboothwilley's Avatar
Fluid up to the curved area is like 1/4 -1/5 of a quart high normally. Not that much extra.
Easy way to let out some fluid but not too much is to use the lines that run to the cooler. You can let out just a little or a lot - if you have the engine running it will pump it out fast.
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
2_Liter_Turbo
Jan 19, 2018 01:48 AM
Hawk196
Sep 22, 2015 02:51 PM
NemesisGee
Aug 11, 2015 07:10 PM
joedaddy1
Jul 28, 2015 02:58 PM
