Its time for 3.5 or 3.6 rear gearing !!!
Old Nov 19, 2010 | 06:39 PM
  #151
OCG35's Avatar
wasnt there some ancillary switch option discussed in the Z forum (a long while back)... I remember when Osiris first started getting hot there was a lot of talk about base model Z (or whatever ones have no cc) not being able to switch maps... I thought someone had an external switch option... I didnt follow to closely since it didnt relate to me at all.
But yes, that is a considerable concern.
Old Nov 19, 2010 | 06:48 PM
  #152
Canadian's Avatar
Canada, eh?
I have no idea haha.. I will have to research. Anyone know?
Old Nov 19, 2010 | 06:52 PM
  #153
OCG35's Avatar
probably quicker to call UpRev - if there is something I'm sure they know about it (unless it was a basic DIY that I'm thinking of... but I'm pretty sure I remember reading they had something)...
I'll be talking with Shawn Church (about other things) pretty soon - I'll ask if he's aware of anything (he's tuned so many Z's I'm sure he's seen it if it exists).
Old Nov 19, 2010 | 08:04 PM
  #154
Canadian's Avatar
Canada, eh?
Cool, would appreciate it if you could let me know. I'll check with UpRev next week.
Old Nov 19, 2010 | 08:36 PM
  #155
NFSP G35's Avatar
? = 2B || !2B
I'm not so sure the inability to activate the cruise control would necessarily prevent you from using their map-swapping functionality.
I mean, swapping maps doesn't really have anything to do with the cruise, it just uses those buttons, right?
Obviously, it's a different story for the Z's that don't have cruise at all, because they wouldn't even have the buttons.
Old Nov 19, 2010 | 09:18 PM
  #156
Canadian's Avatar
Canada, eh?
To use their map switching feature you have to rely on how many times CC blinks. Currently, when I press the CC button it just blinks continuously. So no way to determine what map you are on, even if it still worked.
Old Nov 19, 2010 | 09:33 PM
  #157
NFSP G35's Avatar
? = 2B || !2B
^Ah. Gotcha.
Old Nov 20, 2010 | 10:21 AM
  #158
19kdrill's Avatar
Not to thread hijack, but I found this on Ebay and wondered if anyone has a way to identifying it's specs (3.5 or 3.3, 5AT or 6MT, etc). I searched the part number and found little info. http://cgi.ebay.com/ebaymotors/NEW-O...Q5fAccessories
And, if anyone happens to know if this can be installed in my 03 5AT sedan (without giving me a virtual slap in the face).
thanks,
rob.g
Old Nov 20, 2010 | 10:46 AM
  #159
NFSP G35's Avatar
? = 2B || !2B
^I believe that's just the diff, no gears.
Old Nov 20, 2010 | 01:58 PM
  #160
OCG35's Avatar
yes, thats diff only not gears... find out if it's for MT or AT... if MT it is VLSD if AT its open and not worth considering... if you are AT, you would need 3.5 or shorter to use MT diff anyway.
You would be better off sourcing entire used pumpkin that includes 3.5 (or 3.7) with VLSD.
19kdrill, are you looking for replacement LSD or shorter gears (or both)?
Old Nov 20, 2010 | 02:01 PM
  #161
NFSP G35's Avatar
? = 2B || !2B
That's what I was thinking too.
$300 for the diff, plus how much for the ring&pinion? Wouldn't be long before you could just buy the entire pumpkin.
Old Nov 20, 2010 | 02:05 PM
  #162
OCG35's Avatar
$300 for the diff, plus how much for the ring&pinion(450-500 if new)? Wouldn't be long before you could just buy the entire pumpkin.
yep
Old Nov 20, 2010 | 07:14 PM
  #163
19kdrill's Avatar
I'd say both. Looking for what the OP is looking for. Not very knowledgeable of the whole concept, but if it helps w/ traction, launch or accelleration or something of that nature, it might be money well spent.
Thanks for the assistance ya'll.
Old Nov 20, 2010 | 07:40 PM
  #164
OCG35's Avatar
the gears will help with acceleration - the diff (if lsd) will help with traction... but the unit in the link you posted in diff only.
Depending on your budget, you can get ring & pinion and after market diff and install them in your existing pumpkin (housing)... I got new 3.692fd and Quaife ATB differential a few years ago, good combo (but a little over 2K with install).
Old Nov 20, 2010 | 11:48 PM
  #165
19kdrill's Avatar
^Ouch, 2K? Not really willing to spend that much right now. But thanks for the replies though. Good info!
rob.g
