Anyone replace clutch and keep flywheel?
Old Dec 12, 2010 | 09:21 PM
nicbaines's Avatar
4th gear test= NO GOOD.
the late engagement is typical for stock clutch. you just have to get use to it
Old Dec 12, 2010 | 11:24 PM
gary c's Avatar
Originally Posted by SilverMamba
awesome info gang! not even sure my clutch is bad as it does not slip but only engages on the last two inches of the pedal rather abruptly.
whats the easiest way to see if it's bad? 4th gear at a stop and try to go? if she stalls she is good if not she is bad? hydraulic clutches are new to me!
Make sure your clutch cylinder fluid is full to the line other wise you'll have a lower pedal.
Old Dec 13, 2010 | 10:32 AM
SilverMamba's Avatar
Where is that located under the hood? My car did not come with a book...also what fluid should i top it off with.
Old Dec 15, 2010 | 11:53 AM
B T's Avatar
B T
I'm looking to get the NISMO LWF at some point since it doesnt have the issue with chatter so much as the lighter ones, can anyone tell me what exactly causes the chatter issue? I know its because of the lighter rotating mass, but how does that cause the noise?
Old Dec 15, 2010 | 12:14 PM
nicbaines's Avatar
it is true that the nismo is better on chatter. my buddy has one in his 350z, and there is almost none
Old Dec 15, 2010 | 01:00 PM
Inter_America's Avatar
when i changed my clutch i didn't even take out my flywheel. it just stayed in there. so once i put everything back in there the clutch felt really bad. but only when i was engaging it. once my car was rolling the car felt fine. after about 700 miles the clutch felt fine and nothing was wrong with it. im not trying to encourage you to do the same as i did. but those are just my two cents.
jsimonk
Dec 22, 2023 03:49 PM
EPG35
Aug 16, 2015 04:52 PM
TurboEE
Jul 31, 2015 10:41 AM
socalg35x
Jul 28, 2015 10:42 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
