Occasional grinding shifting into 5th gear, warranty up later this year..
Old Feb 8, 2011 | 08:50 PM
n00b's Avatar
I don't know jack about drivetrain so I was hoping for some advice. The car is an 2004 6mt with just under 50k miles (about 49500). The car was bought in Oct 2004 so it should still be covered under the 7 year powertrain warranty.
The gear only grinds when I shift into 5th fast, if I do it gently there isn't any grinding (however, when I shift fast into all the other gears it doesn't grind). Is there a transmission issue with my car? Should I take it to the dealer while it's still under warranty? Thanks for all help.
Old Feb 8, 2011 | 11:20 PM
n00b's Avatar
actually, after looking further, it appears the warranty is only for 6 years (despite me reading on here that it was 7 years). looks like the warranty is over.
Old Feb 8, 2011 | 11:32 PM
alfhasg35's Avatar
sux.. yep.. ur s.o.l....
Old Feb 9, 2011 | 01:38 PM
maomao's Avatar
I'm having the same problem and going to change my Transmission fluid (and diff fluid) today
Check this thread
https://g35driver.com/forums/drivetr...-start-up.html
Old Feb 28, 2011 | 05:29 PM
maomao's Avatar
Changing my transmission fluid solved the problem good luck!
Picture Share
Feb 4, 2018 12:41 PM
RWDguy4238
Sep 30, 2015 12:13 AM
alinero718
Sep 27, 2015 09:35 PM
blnewt
Sep 25, 2015 01:48 PM
