Sorry for the dumb question, but: Can a 350Z RE5RO5A directly swap into a G35?
Old Mar 21, 2011 | 04:58 AM
MM_G3520's Avatar
Hey guys,
I am looking at some transmission stuff. It might be time to replace my original auto.
Can the 350Z transmission directly bolt onto a G35 sedan?
I found a company that sells rebuilt 350Z RE5RO5A's for a decent price, but they do not offer the service for G35s. Can I buy the 350z part and use it on my car? I figure it's possible because so many parts are interchangeable, but is there any difference between a G35 coupe, 350Z, and G35 sedan RE5RO5A?
Thanks, any help is much appreciated.
Old Mar 21, 2011 | 06:01 AM
Majiks's Avatar
i think only the coupe but this answer is just for the bump and the subscribe to see the 100% answer
Old Mar 22, 2011 | 07:12 PM
MM_G3520's Avatar
Hmmm, I hope not! Anyone know what's different between coupe/sedan transmissions?
Old Mar 28, 2011 | 03:22 AM
MM_G3520's Avatar
This is from the thread I made on my350z.
Originally Posted by bbs350z
yes, same exact trans. had a g35 sedan (03) and part numbers matched 03-05 auto z trans. manual trans are the same as well
DOMO
Old Mar 28, 2011 | 01:05 PM
DaveB's Avatar
You've got an early 03 car, the TCM is going to be different therefore the valvebody may be different. The 04.5 trannies were different (TCM in the valvebody) and the 05/06 trannies were different too (TCM in valvebody, rev match downshift).
If it were me, I'd probably bend over and let Nissan/Infiniti rebuild the one you have rather than go through all the headaches of possibly trying to find out what works and what doesn't. The only people I'd be comfortable with working on these 5ATs is a Nissan transmission specialist.
Old Mar 29, 2011 | 11:46 AM
tony m's Avatar
trans swop
The RE4RO5a trans have many different configurations, computer, gear ratios,colum or floor shift. There is a tag on the back tail housing that gives this the information on its configuration.
Call me if you need a break down on what will enterchange.
Tony M. 214-358-0711
DFW Transmissions
Old Mar 30, 2011 | 01:19 PM
Tollboothwilley's Avatar
The trans will swap but you need to be careful to make sure that you get the correct one to swap into your car. 2003-2004 should swap no problem. You will need to reflash the EPROM on the valve body though or it will not mate up properly with the TCM.
2004.5+ will not work - different valvebody and TCM.
Old Apr 1, 2011 | 04:20 PM
MM_G3520's Avatar
Willey, do you have any pics of the 04.5+ transmission?
Is that when they switched from external to internal TCU?
Old Dec 21, 2015 | 08:39 PM
Angel Mza's Avatar
I need Help please
Hey guys, Can I put a TCM from a 2005 Nissan 350z on my 2005 G35?
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
HypedAndy
Southern California
Jul 21, 2015 03:46 PM
ZacDesu
Jul 14, 2015 11:13 PM
