4.083 FD Rack and Pinion Gear Installed
Old May 9, 2011 | 02:53 AM
eksigned's Avatar
4.083 FD Ring and Pinion Gear Installed
Finally took the time to swap pumpkins. 4.083 FD gear came from a '07 HR Z. The process was actually much simpler than I had initially expected. Couple bolts off the axles (10), drive-shaft (4), and one vac line later, the new pumpkin was in . I unfortunately didn't get a chance to open her up much, but will in the morning on the way down to campus. By the way, the pumpkin's pretty freaking heavy! Caught me a little off guard .
So now, we all KNOW that the rear pumpkin off a 2007 HR Z will indeed bolt DIRECTLY up onto a 37's. The only problem we had were the sensors. Fortunately for us, we were able to retain the individual harnesses per each car (Z's merges, while ours splits off into 2 individual lines). The ABS sensors came right off each pumpkin.
4.083 Rack and Pinion OE (Nissan Pathfinder - forged thicker for towing). Shimmed, upgraded seals and bearing. Chatter free!!!
(2010 G37S 6MT)
Old May 9, 2011 | 10:28 AM
Tollboothwilley's Avatar
Should be noticeably faster...3.69 to 4.08 is a good step up
Old May 9, 2011 | 06:19 PM
OCG35's Avatar
ring and pinion - not rack and pinion... its rear end gears not steering
Old May 9, 2011 | 07:21 PM
ooh, but what if it was RAS
Old May 9, 2011 | 08:05 PM
OCG35's Avatar
^^^ only thing I can think RAS means is rear assisted steering?
Old May 9, 2011 | 11:43 PM
eksigned's Avatar
I'm literally...speechless. LOL thanks for lookin' out OCG!
Old May 15, 2011 | 01:07 AM
whoisthis's Avatar
How much did you pay for this rack and pinion gear? LOL
srlsly, how much?
Old May 16, 2011 | 12:36 AM
RAS = Rear Active Steering. An available option on the G37S I believe.
I was just joking about having a "rack" out back if it had RAS.
chinee
Jun 10, 2024 07:48 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
1OG35
Aug 7, 2015 11:25 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
