My clutch pedal is stuck on the floor
Last night, my clutch was stuck to the floor and I couldn't get it in gear. When I got into gear, the pedal was still stuck and I had to kick it back out to change the gear.
Went to search for reasons for this issue, I found something about changing the clutch fluid. Here's the site https://g35driver.com/forums/drivetr...me-here-3.html
I did what it said and my clutch is still stuck on the floor. My car starts but will not go into gear! After I turn off the car, the gears work. I replaced my clutch 2 years ago at 95k. My clutch is at 128k right now. Could this be a master / slave cylinder or something else?
Does anyone have any idea or suggestion what could be wrong or help fix this problem? My funds are really tight...please help
This is order of diagnosis
Replace fluid with Dot 4
Bleed lines
Replace slave / bleed lines
Replace master / bleed lines
Replace Clutch line(only if bad)
Replace Pivot Ball
Replace Throw out bearing
Replace Flywheel
Replace Clutch
Replace Tranny
Replace CAR
http://my350z.com/forum/maintenance-...the-floor.html
Parts
https://g35driver.com/forums/g35-sed...arts-sale.html
https://g35driver.com/forums/engine-...-shipping.html
www.rockauto.com
Bleed lines
Replace Pivot Ball
Replace Flywheel
Replace Clutch
Replace Tranny
Replace CAR
Parts
www.rockauto.com
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
jbmw002
Sep 10, 2015 12:54 AM
