Gear Shift Indicator Went Blank - Car Starts & Drives
Old Oct 4, 2011 | 08:40 AM
Metalp3n's Avatar
Exclamation Gear Shift Indicator Went Blank - Car Starts & Drives
About 5 days ago I had my transmission rebuilt - and everything has seemed fine since then. Smooth shifts, no noises at all. Yesterday however I noticed that shifting out of park into drive causes the car to jolt forward (something it used to do with the old tranny but did not when I first got it rebuild). I have not really pushed the car yet - and have been waiting to give the new tranny time to break in.
Last night I drove into my banks drivethru, put the car into neutral (AT) and noticed nothing lit up on the gear indicator on the dash. I went into drive, and it drove forward - but nothing lit up. Park, Reverse, Neutral - all led to no display on the gear indicator. I put her into park and turned the car off and on again - and everything was fine again. I drove away - got home (about 2-3 mintues drive literally) - parked the car and noticed when going from Drive into Reverse (thus passing Neutral) the gear indicator went blank for a second as it passed over Neutral - then lit up Reverse. I went back into Neutral - this time the delay was a bit longer but it did eventually display the N on the indicator.
I dropped her back off at the shop very early this morning and will see what they have to say - but I wanted to get some opinions on here on what you guys think the reason could be.
Old Oct 6, 2011 | 02:56 PM
Metalp3n's Avatar
bump?
Old Oct 11, 2011 | 01:46 PM
saintgotech's Avatar
Did you get the problem corrected
Old Oct 12, 2011 | 05:31 AM
Metalp3n's Avatar
It took a few more trips to the shop to finally settle this away. I will have videos and an explanation up later on today for anyone who might have a similar problem - although it seems not many do.
Old Oct 25, 2011 | 02:47 PM
Metalp3n's Avatar
So, the video's are uploading and will be online later on tonight - at which point I will edit this post to include them. However what the issue actually was:
The trans temp sensor seemed to have went bad (why I really do not know as it was perfectly fine prior to the tranny rebuild) and as such when I would drive the car it wouldn't ever send a consistent signal to the ECU - as such the transmission thought it was hot one second, cold the next, warm the next, cold the next, etc. If the transmission fluid hasn't properly warmed up the car will lock you out of the top gears until it deems it safe - however with constantly changing signals this becomes a very hard task for it to do. When you go to over-take a car - give it some extra gas - it downshifts into 4th - then when it's time for it to upshift it gets told it's cold - it will continue to hold 4th gear - then suddenly it gets told it's warmed up so it upshifts - only to be told that now it's cold again and it really shouldn't be in 5th. At this point the tcm seems to just give up - and the gear indicator goes blank. The shifts become extremely rough - and each gear is held for much longer than it should be.
I had the shop swap the temp sensor - and everything was back to normal.
Old Oct 25, 2011 | 07:32 PM
04G35NYC's Avatar
Glad everything works fine now.
Old Feb 20, 2020 | 12:59 PM
Bolas's Avatar
Original Owner
------ Hello, Here because similar issue. But in addition to not seeing what gear you are on.... car does not even crank/start anymore. Thinking it may be some sensor which has it in "safe mode" to not start.
So did replacing the Temperature Sensor fix your issue? (Engine Temp sensor or Transmission Temp Sensor?)
Thank you
Old Feb 20, 2020 | 06:36 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you can't see the gear and it won't crank that makes me suspect the park/neutral position switch on the side of the transmission.
Old Feb 29, 2020 | 12:21 AM
Randy White's Avatar
2013 sonata GLS
This literally just happened. Car will not start now and gear display is blank. Any idea how to fix that switch??
Old Feb 29, 2020 | 11:19 AM
cleric670's Avatar
BANNED!!!
There's some troubleshooting steps in the FSM to make sure it's not a damaged harness or wiring, the switch itself is part of the valve body and not typically replaced by itself.
I would run through ALL the gears to see if anything lights up. Before you go digging into the transmission you should check EVERY SINGLE FUSE to make sure something didn't pop. There are 3 fuse locations, Fusible link, IPDM both in the battery compartment, Fuse Block - J/B in the cabin.
Make sure to disconnect the battery before working on any of the electrical system or you can cause bigger problems.
Old Apr 9, 2020 | 09:39 PM
good gravy's Avatar
04 Infiniti G35 Coupe AT blk
just experienced this problem. old thread so I made a post about my experience, here's the link
https://g35driver.com/forums/engine-...ml#post7187137
anyone end up finding the solution to this??
626Gthirtyfive
Nov 14, 2010 10:31 PM
osamabinwayne
Drivetrain
Feb 8, 2007 09:10 PM
mistermojorizin
Drivetrain
Nov 2, 2006 06:23 AM
Jining
May 15, 2006 02:51 PM
Skyline_G35
Drivetrain
14
May 26, 2004 08:54 PM
