What is this hole above rear diff?
Old Oct 7, 2011 | 09:41 PM
adequ's Avatar
This is not my car. Had my car up on a lift today and I didn't take a picture of this...Stupid, I know.
That hole that is circled in red...what is that? I was changing my fluids and I noticed that there was some oil or lube or whatever that had leaked from there. Should I be worried about this?
Old Oct 7, 2011 | 09:48 PM
faiz23's Avatar
diff bushing
Old Oct 7, 2011 | 09:54 PM
adequ's Avatar
Originally Posted by faiz23
diff bushing
Assuming fluid is not supposed to leak out of that? Thanks for the response.
Old Oct 7, 2011 | 09:56 PM
GreenGoblin's Avatar
The goblin resurrection
The oem is a liquid filled, when it is leaking that means on of the chambers has ruptured.
Old Oct 7, 2011 | 10:24 PM
adequ's Avatar
Thanks everyone. From this information I was able to do a better search. I'll take it to the dealer and have them fix it under warranty.
Also, the car makes the "ticking" or "clicking" noise when ever I start out in first gear..and sometimes into second and third. Been told that this is a common problem with the G and that the axle needs to be cleaned, lubed, and re-torqued. Could this blown bushing thing be the cause of the noise?
Old Oct 10, 2011 | 06:52 PM
adequ's Avatar
Nissan dealership said the bushing was in perfect working order, so I am assuming that whoever had the car before me had it fixed - bc that was definitely silicone that was all over. Charging me almost 400 bucks to clean and lube the axles. Does that sound about right?
Old Oct 10, 2011 | 06:55 PM
1SickVeilsideZ's Avatar
^^Might want to get a second opinion, if it was leaking chances are it's probably gone.
Old Oct 10, 2011 | 06:59 PM
adequ's Avatar
Originally Posted by RICK@OCINFINITI
^^Might want to get a second opinion.
Good advice. I was trying to save money by going to the local Nissan dealer instead of the Infiniti dealer - which I am sure is automatically going to charge more money for everything.
Old Oct 10, 2011 | 07:32 PM
^^Not always the case, but labor rates do vary from dealer to dealer. NISSAN dealers can service INFINITI vehicles, but they will tell you that they can't do anything for you on warranty claims since they're not authorized to do them only INFINITI dealers are (even though the parts numbers are the same). If your car is still under warranty you shouldn't have a problem, but don't quote me on that since EVERY dealer is different.
Old Oct 11, 2011 | 08:45 AM
Blue Dream's Avatar
I drove ttrank's car solo
If you can turn a wrench the axle click is an easy fix. Buy a $6 tube of synthetic grease and a wire brush and your good to go. Should only take you 2 hours or less to do both sides. beats paying the dealer $400
Old Oct 16, 2011 | 07:50 PM
adequ's Avatar
I'm not very skilled with tools. I also have a bad habit of stripping and/or breaking items that I try to handle myself.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
derres
Aug 28, 2015 03:27 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
edwinisdumb15
SOCAL Meetings & Events
Aug 3, 2015 10:42 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
