2003 G35 Coupe ATM Transmission Issues
Old Oct 11, 2011 | 01:40 PM
saintgotech's Avatar
Hey does anyone on this forum have any issues with there Automatic transmission when moving from
[P] Park to [D] Drive. My issue is when placed move to [D] it takes a wile for the vehicle to move. Also if I come to a complete stop and then try to move off there is a delay and then it moves. this does not happen when I use the Tip-tronic mode or manual mode. Please advise thanks
Old Oct 11, 2011 | 01:47 PM
Canadian's Avatar
Canada, eh?
Sounds like you need to do a trans fluid drain and fill. How many miles on the fluid? Also, your fluid may just be low. Go check it, the dipstick is behind the motor.
Old Oct 11, 2011 | 02:04 PM
GR6RR's Avatar
drain and fill... should help.
also, make sure to use OE Nissan Matic fluids, J or S will work.
Old Oct 11, 2011 | 02:47 PM
Thanks guys, not sure how many miles on the fluid I recently purchased the car. I will check the fluid level and see, if it's low, then ill will tap it up if that does not work I will do the drain and fill. Thanks again
Hasanbaloch
Feb 29, 2024 08:45 PM
TWASkyliner
Feb 8, 2020 08:00 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Chattzx
Jul 17, 2015 11:23 AM
