Short shifter cup install help
Old Jan 8, 2012 | 03:50 PM
.cakestar's Avatar
So i am in the process of installing a short shifter in my car and i purchased a new shift cup. I cant seem to get the damn thing on. Im pressing as hard as i can and its all greased up too but it just wont go in. Anyone have any tips on how to install this thing?
Old Jan 8, 2012 | 06:38 PM
.cakestar's Avatar
Anyone?
Old Jan 8, 2012 | 06:51 PM
alfhasg35's Avatar
I put the cup in between two bricks so the shifter can fit through without hitting the concrete and i just put all my weight on it.. I only weigh 160lbs. Snapped right in.. First time, no problem.. If u do a search people have used this method..
Old Jan 8, 2012 | 07:36 PM
.cakestar's Avatar
Ah got it finally. When i am testing the gears i can go into all of them but i cant press down to get into reverse. Is something misaligned?
Old Feb 2, 2012 | 04:31 PM
bhibler83's Avatar
Quick question. The Infiniti dealership I'm dealing with is stupid, they don't seem to know what the shifter cup is. Do you have a part number I can give them so I can move on with replacing mine?
Thanks for your time.
Old Feb 11, 2012 | 09:07 AM
06infinitig35's Avatar
From what I was told, you must buy the complete oem shifter from the dealer to get the plastic cup.. You can't just buy it sepert I tried. Correct me if I'm wrong anyone!
Old Feb 11, 2012 | 10:37 AM
alfhasg35's Avatar
Pretty sure u can buy it separate..!!
Old Feb 11, 2012 | 10:46 AM
Bump, is that the part number for 06 6MT G coupe by any chance?
Old Feb 11, 2012 | 10:51 AM
How much did you pay it!
Old Feb 11, 2012 | 11:16 AM
alfhasg35's Avatar
Mine was a 2005 6mt and it worked perfectly.
I think they run like $20-$30
Old Feb 11, 2012 | 11:18 AM
alfhasg35's Avatar
$12
Google is ur friend..
http://www.nissanpartszone.com/parts...870-ac800.html
Old Feb 11, 2012 | 02:38 PM
.cakestar's Avatar
If Infiniti can't find on in their database go to Nissan. Infiniti has it cross referenced under a diff part number
Old Feb 19, 2012 | 03:39 AM
hey guys! so i attempted to install my stillen short shifter on my 06 G35 coupe and none the less all went smooth up until i had to press the old shifter out of the cup. i used the vise method but without any luck. three fins cracked off while pressing it out. i saw this coming a mile away. im gonna go see nissan on monday to see if i could order the cup :s my question is..... what method are people using to do this. im out of options, but the logic behind it seems to be quite simple. has anyone tried heating up the cup while pressing in a frozen shaft. maybe that might work. thanks in advance, all help is appreciated
Old Feb 19, 2012 | 04:37 AM
.cakestar's Avatar
Oh oh! I have a perfect solution for this. So what I did was take a jack stand, remove the adjustable piece so you are just left with the stand a squareish hole. I put the short shifter in and use two long pieces of metal on the sides of the cup. Used a wrench and a big flat head screw driver. The thing went in super smooth and there was no damage to anything. The hole of the jack stand was perfect to fit the shifter in.
Old Feb 19, 2012 | 09:10 AM
Okay sounds like a plan! As soon as I order one monday morning I'll try it out the way you said. I'm gonna call nissan and give the same part code as the one you have dispalyed on the thread. I hope it'll be the same for a 06 G coupe! Will update this week! Next solution is pop it on a drill press and press this thing in before I loose my mind
