5th gear syncro possibly
Old Jan 8, 2012 | 04:30 PM
rForce's Avatar
Everytime I shift into fifth gear from 4th above around 2k rpms and downshift from 6th you can hear a sharp grinding noise, the higher the rpms and the faster the shift the louder the grinding is. Ive looked around and made a previous thread and from what I see it seems to be a problem with the 5th gear syncro. To fix this do I need to replace the whole transmission or just repair it and does anyone have any idea how much it could possibly cost to fix? Can i keep driving in fifth or should i get this fixed right away because i need to use the highway to get to school and work five days a week. Any advise would be helpful, thanks.
Old Jan 17, 2012 | 09:52 PM
itsmednyce's Avatar
i have the same problem and reverse started to grind once in awhile in my 04' 6MT
Old Feb 26, 2012 | 02:50 AM
Sleeper11311's Avatar
I have the same problem on my 2003 G35. It grinds going in to 5th if I shift normal or fast but if I go slow there is no grind. I have an extended warranty that covers the internal parts of the transmission but only if they find broken or damaged parts inside the transmission. I am an ASE master certified tech and I am almost 100% sheer that the problem is the synchronizers but I don’t have much experience with these transmissions and I wanted to know if anyone has had their transmission torn down and if there was a visible problem that could be verified.
Old Mar 3, 2012 | 03:34 PM
sikskyline69's Avatar
g35
i have an 03 6mt and mine is doing that exact same thing. Hoping some one can give me some insight on fixing this problem
Old Mar 4, 2012 | 03:07 AM
rForce's Avatar
I phoned a transmission shop and a fifth gear synchro is around 1700 to fix, he also quoted me 2100 for a transmission rebuild and 2700 for a whole new tranny. Ive decided to get a whole new cd009 tranny put in as it sounds like the synchros are alot better with it and the synchros could go out again with just a repair. I live in Canada so it might be cheaper in the states and i plan on phoning a few more places to see if i can find a better price
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
magnetism80
Jan 27, 2016 12:57 PM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 06:46 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
