oil cooler help
Old Feb 1, 2012 | 08:02 PM
kristinavq's Avatar
oil cooler help
hi guys im new to the forum (= my name is kristina i recently tried to change my o-ring on my oil cooler . i took off the oil cooler and the ring fell out !! didnt see which way to install so i installd but had to stretch it out on 1 of the circles!! now my oil cooler is leaking even more !!! so my question is how do you install correctly and if i take off my oil cooler will all my oil drain out ?? i just put royal purple in it and it isnt cheap
Old Feb 1, 2012 | 08:07 PM
kristinavq's Avatar
also how much do i torque the oil cooler back down ??
Old Feb 1, 2012 | 09:17 PM
AreSicks's Avatar
You placed the o-ring behind the cooler right? Torque on the connector bolt is 36 ft/lbs.
Old Feb 2, 2012 | 08:46 AM
kristinavq's Avatar
yes but it still leaking i was thinking i didnt put it on right or i didnt torque it enough
Old Feb 2, 2012 | 09:34 AM
kristinavq's Avatar
also when u installd it did you have to stretch the o-ring out to fit ?? and if i tak it off will all my oil drain out ?? or just a quart ??
Old Feb 2, 2012 | 10:02 PM
AreSicks's Avatar
It fits around the center hub of the cooler. Should look like this...
Old Feb 29, 2012 | 02:34 AM
kristinavq's Avatar
thanx a million
Old Mar 8, 2012 | 08:41 AM
jmueller's Avatar
Is there a DIY for this? I have searched everywhere.
Old Mar 8, 2012 | 10:36 AM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
is it possible you need another O-Ring? yours worn out? that's usually why it leaks....
anyway hit your local Nissan/Infiniti and get 21304-JA11A if you need one!
Old Mar 8, 2012 | 10:14 PM
jmueller's Avatar
I believe I do need one. I would love to know what I am doing though. DIY!
Old Mar 9, 2012 | 12:00 AM
kristinavq's Avatar
when u figure it out its very easy just take off oil filter take off the bolt i think its a 19mm or 21mm and remove it pop off the o-ring and put the new one on and put everything back on and torque 35lbs my problem i bought a messed up o ring
f22raptor
Mar 18, 2016 08:50 AM
mbe32
Nov 13, 2015 11:09 PM
dseet
Oct 11, 2015 12:40 AM
9tray turbo
Sep 29, 2015 10:22 PM
