Is this diff fluid ok?? Need answer asap!
Old Apr 6, 2012 | 02:53 AM
midnighttheg35's Avatar
I went to part source to get amsoil 80w90 diff gear oil but they were out the guy sold me chevron and said its just as good and will work great. Ive always thought chevron was....not so good. Can i still use it? Im planning on doing the change in the morning so i need to know
Its still synthetic, 80w90 gl5 diff gear oil. Is it okay??
Thanks!
Old Apr 6, 2012 | 04:03 AM
LSGoose's Avatar
I think as long as it is GL-4 or GL-5 oil you should be ok. I'm sure someone with more knowledge will chime in shortly.
Old Apr 6, 2012 | 08:48 AM
gary c's Avatar
Believe it or not Chevron is a quality company, if you can't afford AMOSIL or Red Line it will do fine....Gary
Old Sep 13, 2013 | 02:29 PM
JayVQ's Avatar
Sorry to bump an old thread. I am having a hard time finding anything GL-4 on store shelves but found some valvoline that says it meets the requirements for GL-4 and GL-5. Is this ok to use in the transmission?
Old Sep 13, 2013 | 07:14 PM
LoSt180's Avatar
No.
Use Nissan MTF or Redline MT85. Typically have to order it, never seem to find it in stores.
Old Sep 13, 2013 | 08:47 PM
wallofgrath's Avatar
Yeah you've got to order the transmission fluid, but the rear diff fluid you can find in any auto parts stores (Valvoline or Lucas 80w90 is what I always see)
Old Sep 15, 2013 | 07:40 PM
Mustang5L5's Avatar
No. gL-5 fluids can be corrosive to yellow metals (bronze, copper, etc) and should not be used in transmissions spec'ed to gL-4.
However, in rear axle applications, there are no yellow metals, so gL-5 fluids are acceptable.
I used Mobil 1 75w-90 in my front and rear axles.
Old Sep 15, 2013 | 08:26 PM
JayVQ's Avatar
This much I knew but how is it they can say right on the bottle that it meets requirements for GL-4 if it will eat up the components?
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
f22raptor
Mar 18, 2016 08:50 AM
Rose M
Oct 12, 2015 10:00 AM
AL8782
Oct 3, 2015 10:26 AM
Learned Hand
Oct 1, 2015 09:02 AM
