FS: Spec clutch & act prolite flywheel & oem clutch & flyewheel
Spec clutch & act prolite flywheel & oem clutch & flywheel
SOLDI have a spec stage 2+ clutch and pressure plate for sale. No problems at all and was not slipping when i pulled it off. Nice streetable single diskl. Im selling it fairly cheap to give someone the option of purchasing a new disk. They range from $150 to $300 depending on the stage you buy.
$100 + shipping
SOLDThe next item is a ACT Prolite 13LB flywheel. Made of chromoly steel. Will need turned before installing it.
$200 + shipping
$100 + shipping
$200 + shipping
Question if I have a forced induction between 500-600hp will a stage 2 be enough? I have a jwt clutch and its starting to slip badly I believe. I dont know if its the CSC or something else im going in tomorrow to see. I am just seeing if this would hold up.
I was making about 630whp with this clutch and didnt have a problem. Its a stage 2+ which has an increased torque capacity.
