pilot bearing?
Old Jul 1, 2012 | 01:52 AM
dfwgsx's Avatar
pilot bearing?
I just purchased a 05' G35 coupe 6MT and there is a distinct noise coming from the transmission in the clutch area. When the clutch pedal is all the way out the noise is a clattering sound, but when you push the pedal in the noise goes away but you can slightly feel a little vibration in the pedal. I'm not sure if the pilot bearing needs replaced, or if the car has an aftermarket clutch. This is my first G and im still in the learning process, any help would be appreciated. Thanks Matt
(i will try to get a video posted of it shortly)
Old Jul 1, 2012 | 01:53 AM
AlwaysG's Avatar
Sounds like it, I had a Honda that did the same thing and that's what it turned out to be.
Old Jul 1, 2012 | 02:34 AM
dfwgsx's Avatar
http://youtu.be/Fh24Rwkv2vs
here is a video I took before i bought the car, so excuse the extra walk around. The first 10 seconds are of the chatter/clicking. The clutch seems to grab fine, just heard of some weird noises with aftermarket clutches/flywheels. And i cant be certain if it has a stock clutch or aftermarket without taking it apart.
Old Jul 16, 2012 | 12:23 PM
dfwgsx's Avatar
I bought a competition clutch am in the process of replacing it. Do you just remove the old pilot bearing and slide the new one on and it should fix the noise?
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
AL8782
Oct 3, 2015 10:26 AM
gqraverice
20 Inch
Sep 29, 2015 05:39 PM
