I took my car to an independent shop to have some work done. When he pulled it into the shop he accidently bumped the shifter over to manual mode and the shifter got stuck in manual mode. He called me and asked if I had ever had the problem before and I told him I hadn't. He was able to get the shifter out of manual mode by taking it apart, but now I have to have the shifter in manual mode for the transmission to recognize it as being in normal drive mode. Also, the display on the dash doesn't show the "P" "R" "N" anymore. He has offered to install a new shifter, no charge labor, if I pay for the part ($400). I'm not willing to do that and may have to take him to small claims court. Any ideas on how to fix this without buying a new shifter?
JaE35
Moderator
close
- Join DateJul 2010
- LocationDFW, TX
iTrader Positive Feedback100
iTrader Feedback Score(37)
- My RideG35 Sedan
Liked:802 Times in 678 Posts
Sounds like an issue with the valve body unfortunately..even if he did it on accident something like this would've happened eventually. i'd definitely put up a fight to have them fix it though
I consulted with a Nissan mechanic and he said it was the shifter assembly, that there is a tab in there and when it is damaged it doesn't know if it is in manual or regular drive mode. I ordered the shifter assembly from infinitipartsusa. Part # 34901-AC30A . They call it a Device Assy - Transmission. It is about $100 cheaper than going through the dealership and the cheapest I could find it online. Since there is no way to prove the mechanic did it I'm just going to pay for it and install it myself.
bigc
Wings Nation
close
- Join DateFeb 2007
- LocationSoCal
iTrader Feedback Score(59)
Liked:626 Times in 456 Posts
ugh, that blows. glad you figured it out and can resolve the issue without using the stealership
This definitely does suck man. And no don't pay for the part for the free labor, he messed it up it should all be on him. It's like when an independent shop broke my TPMS and said oops and didn't want to pay for anything, like no you break it you buy it.
Hey man was curious if you ever figured out the problem! My buddy is having a similar problem and was curious what to do! Thanks.
cleric670
BANNED!!!
close
- Join DateMay 2017
- LocationWashington State
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideCoupe 6MT Premium RAS
Liked:2,497 Times in 2,182 Posts
Scroll up 4 posts and you'll find his answer to what the problem was.
