Clutch Hydraulic System
Old Nov 19, 2013 | 08:42 PM
ckendG35's Avatar
Hello,
I have an 2004 MT6 coupe. Today on my way to work, the pedal to the clutch felt really soft until halfway engaged. Could shift gears but really hard if clutch pedal was not pressed half way to the floor board. So after work started the car up fine, went to engage the clutch pedal and I mean all the way to the floor board and could not change into any gear. Had it towed to an Infiniti dealer and the technician told me there was a break in the line for the clutch hydraulic system. Would there be any damage to the flywheel or pressure plate during driving when the clutch pedal engaged gears only half way The pedal has always had a firm pressure feel when engaging gears, this had a really soft feel. Just want to make sure no other damage was done while driving with a leak in the hydraulic system?
Old Nov 20, 2013 | 08:10 PM
N8Deezy's Avatar
You can drive a MT without using the clutch. I just wouldn't recommend it.
There is a chance that the throwout bearing would cause a metal to metal contact and damage the pressure plate. And if you have a known leak in the hydraulic system you should fix it asap or more damage will potentially occur.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
