REQ: Auto tranny DIY
Old Feb 7, 2005 | 05:27 PM
dwoloz's Avatar
Theres a serious lack of DIY articles
There are the old ones but theyre all totally useless now because the pictures are gone
Some people need to step up and help out the new owners (like myself) with new DIY articles
Would be appreciated greatly
Automatic transmission and differential fluid changes specifically Id like to see
(I have the service manual but theyre skimpy on details and pictures)
Old Feb 7, 2005 | 09:50 PM
KAHBOOM's Avatar
As regards the Auto tranny fluid change- I think that it is recommended to only have this done at the dealer. I'm not sure if that is true or not but I though I read that somewhere.
Old Feb 7, 2005 | 10:26 PM
GurgenPB's Avatar
there was a DIY article on the diff fluid change, complete with picture... As far as transmission, it's very easy/ The only requirement is to use the Nissan Jmatic fluid, and NO other... The other differences are the fluid capacity (8 quartz changeable i believe, look it up the in others manual) and the fluid level checking procedure (the car should be at normal operating temp, idling). Also, make sure that you actually have a dipstick in the filler tube, as some of the earlier cars only have a plug (including mine). If oyu don't, you are going to have to order one from thedealer (the cost was $10-15 i believe).
Good luck
Old Feb 7, 2005 | 10:50 PM
dwoloz's Avatar
I bought Jmatic fluid today but only 4 quarts of it; that **** is expensive!!
10 dollars a quart
Havent heard anything definite about how much you need
There is a diff change DIY but the pictures are dead (like pretty much every other DIY)
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Charchar66
Dec 19, 2019 01:17 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
