FS: RJM Adjustable Clutch Pedal
Old Oct 21, 2015 | 08:12 PM
bchalks's Avatar
Version 2.2 RJM clutch pedal. Used for less than 10k miles. Comes with all necessary hardware. Simply unbolt your stock pedal and bolt this one in.
$100 shipped
Old Oct 25, 2015 | 02:15 PM
danielidiaz13's Avatar
Does this make pressing on the clutch more softer than oem?
Old Oct 25, 2015 | 05:33 PM
bchalks's Avatar
Yes. The pedal is easier to push and more linear.
Old Nov 23, 2015 | 07:54 PM
bchalks's Avatar
bump.
Old Nov 24, 2015 | 11:44 PM
Jamean's Avatar
Is there any adjustability in pedal feel like the newer versions or are you stuck with what you get with the 2.2
Old Nov 24, 2015 | 11:52 PM
bchalks's Avatar
Not exactly sure what you mean but the pedal is much easier to modulate as it engages the clutch in a more linear fashion.
You can change the engagement point from high to low and the engagement window from short to narrow. You can also make the pedal stiffer or softer.
This is the same overall pedal as the later versions, but the way you adjust it is different. The new ones use a dial and the clutch fork. This one uses 3 bolts and the clutch fork.
Old Dec 2, 2015 | 08:24 PM
bchalks's Avatar
Sold
wreaks
17 Inch
Nov 12, 2015 03:46 PM
briang995
Nov 4, 2015 08:58 PM
BowWizzel
Steering & Suspension
Oct 20, 2015 09:13 PM
Crespo
Engine - Intake/Fuel
Oct 18, 2015 01:08 AM
