Transmission Issues
Old Oct 23, 2015 | 07:48 PM
G35CoupeS's Avatar
Transmission Issues
What's up guys I'm a newbie here. Well I seem to have issues with my gearbox and transmission I think but not sure. It's an Automatic with 109k miles.
First Issue: I like driving it in Semi-Automatic but somehow when I came from shopping it wouldn't recognize it and show drive. My little bro told me to let it cool down than after 3 hours wallah it showed 1m. Also this Is a new issue the second and third has been happening.
Second Issue: Sometimes it won't go to park so I have to go to D than P than it will shift there.
Third Issue: When I'm driving sometimes I have to give it more gas and it feels like it slips only in first gear around 1-2k rpm and also I feel a small delay sometimes.
So let me know what you guys think if the transmission fluid should be changed but I'm scared because I've read Forums where people say it ruined there transmission. Also am I the only that has where my pedal goes to the floor.
Old Oct 23, 2015 | 10:34 PM
Jchase22's Avatar
Hey I have an 04 g35x with 146k and feel that same slip and small delay after a sharp stop. Cant quite figure it yet. I would love to know the answer as well.
Old Oct 23, 2015 | 10:43 PM
hurleyguys's Avatar
well i would assume you would need to change your trans fluid. i change mine every 40k miles. i am at 130k with no issues. you also mentioned that your pedal goes to the floor. which one are you talking about since you have an auto?
Old Oct 23, 2015 | 11:35 PM
G35CoupeS's Avatar
im referring to the gas pedal
Old Oct 23, 2015 | 11:37 PM
G35CoupeS's Avatar
Same I hoping a change of fluid would fix it but need expert answers so I don't screw up. I've heard it's bad to change the oil at this high mileage if it hasn't been done for a long time not sure when the previous owner did it.
Old Oct 23, 2015 | 11:51 PM
G2B35AGN's Avatar
You don't want to flush it. Drain and fill only. Some folks do a drain and fill, drive it for 1K miles, do another drain and fill, and keep on until it drains clean. It's expensive due to cost of the fluid, but the idea is that you gradually wean it from the friction components in the old fluid. A flush will drive all of that "beneficial gunk" out, and then the transmission slips. Also, only use OEM Nissan fluid as recommended.
Old Oct 24, 2015 | 02:19 AM
hurleyguys's Avatar
its exactly as G2B25AGN said never flush, only drain and fill.
as to the gas pedal, i have an auto also and mine goes to the floor... what exactly is wrong with the gas pedal? does it not work?
Old Oct 24, 2015 | 08:00 AM
G35CoupeS's Avatar
Nvm I guess it's normal just I expected the pedal to be soft I just touch it and the car will go. Thanks and I'll drain and full of today. Do you guys know where to get the transmission fluid and how much.
Old Oct 24, 2015 | 08:05 AM
G35CoupeS's Avatar
Do you know what type of transmission fluid is it S Matic NissanAutomatic TF
AustinErkl
Feb 8, 2021 06:41 AM
JM Auto Racing
Cars For Sale-Vendor
Feb 3, 2018 11:35 PM
aroundincircles
Jun 12, 2017 11:01 PM
Detailed Image
Oct 19, 2015 07:59 AM
metallemur
Oct 18, 2015 03:00 PM
