Adding fluid after leak
Old Mar 24, 2016 | 11:40 PM
Giolla's Avatar
Hi all,
I found someone with somewhat similar situation in this thread however i feel my situations is a little different >> https://g35driver.com/forums/drivetr...n-fluid-q.html
Car: 2005 Sedan
I changed a radiator because of a leak and my douchebag mechanic left one of the trans cooling lines loose. I drove about 15 miles before noticing there was a leak when i praked at home. I called him and drove it back (another 15 miles) to the shop so he could fix it. He told me i need to add about a quart to the system. Drove back and parked at the house. Did not notice anything weird while driving.
Here's my dilemma: I bought the car with 90K miles on it. According to carfax It used to be a fleet car for some corporate dude up to 40K then another owner who i bought it from. Guy had all maintenance records and there is no record of tranny change/flush. I took it to the dealer when i bought it first and they recommended a tranny flush (of course i refused).
So, as far as i can assume tranny fluid hasn't been changed at least since 40K, and since it was a fleet car if the dude did service it he "probably" took it to the dealer where they would have used Matic - J... I found Matic-J on amazon (all dealers carry Matic -S now). So i'm getting one quart tomorrow but i've been reading posts here and getting a little concerned. Should i just top off with Matic -J or am i taking a gamble and it is a better idea to drain and fill over and over?
Thank you for help
Old Mar 25, 2016 | 11:15 AM
coffeysm's Avatar
Originally Posted by Giolla
Hi all,
Car: 2005 Sedan
Thank you for help
I'd double check the fluid first to make sure it's only down a quart. If you have the money though, I would just do a bunch of drain and refills. I had it done by a Nissan dealer at around 51K miles and then did a bunch of drain and refills myself at around 122K miles. I used Idemitsu Type-J fluid though, which is just as good. You can usually find a good deal on it as well.
Old Mar 25, 2016 | 12:52 PM
LoSt180's Avatar
Was it just loose and leaking a little bit, or disconnected and dumping fluid all over the road?
I'd take it to Nissan for a drain and fill. Probably due to be replaced anyway. Nissan dealer told me the "new standard" is to just do a drain and fill on auto transmissions since flushes tended to cause issues, mainly because people tend to go so long between changes.
Old Mar 25, 2016 | 01:09 PM
Giolla's Avatar
Well, i'm not exactly sure about the rate at which it was leaking but apparently it got rid of a quart in 24hrs. I've not driven it since it fixed the leak.
My question is whether adding 1Qt of fresh matic J could potentially hurt my tranny which i've had no real problems with. I'd rather not do drain and fill because according to some people that too involves a risk when the mileage is pretty high (110K in my case) and running on original fluid
Old Mar 25, 2016 | 05:18 PM
danoman32's Avatar
Well technically you've already done the drain, in a drain and fill. Your options now are run around with low trans fluid or add till it's full. I would rather add till it's back to full versus driving without the proper amount of fluid. Also, I did a drain and fill at 100k, I had now idea when the last time it was changed. No problems....at 135k now.
Old Mar 26, 2016 | 12:05 AM
Giolla's Avatar
Yup, that's the idea.. so i'm gonna top it off with whatever fluid i'm missing and see what happens. I will update regardless.
Thanks for your input guys
dstory
Sep 14, 2015 01:42 PM
taimysho0
Dec 16, 2013 01:20 PM
blkdragn
V36 Engine, Exhaust, Drivetrain & FI
13
Oct 1, 2009 10:56 PM
