Differention and transmission fluid opinion
Old Feb 7, 2018 | 12:32 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
https://g35driver.com/forums/g35-sedan-v35-2003-06/461849-mechanic-used-off-brand-transmission-fluid-do-i-need-concerned.html
Read post #10 for some insight into how the myth started...
Old Feb 7, 2018 | 12:33 PM
cleric670's Avatar
BANNED!!!
Yes drain fill every 30k is the service, NOT a power flush.
Old Feb 7, 2018 | 12:35 PM
cleric670's Avatar
BANNED!!!
7AT is tricky to drain/fill but the steps are in the FSM if you want to do it. 7AT does not have a service interval and is "lifetime fluid" for many of the reasons I posted in the link to the short story.
Old Feb 7, 2018 | 12:43 PM
FreshLikeAG's Avatar
Interesting read.
My service adviser at infiniti had never heard of power flushes causing problems in RARE cases. I later found out that he was not trustworthy after screwing me on a service I didn't need. That dealer has some serious corruption going on. I bet if I paid for the service they would just do a drain and fill instead of a flush for over $200. The only thing they would flush is my wallet!
Old Feb 7, 2018 | 12:45 PM
telcoman's Avatar
Veteran: Army
Nothing like creating a problem where one did not exist.
https://g35driver.com/forums/g35-sed...ml#post7129287
Telcoman
Old Feb 7, 2018 | 12:49 PM
cleric670's Avatar
BANNED!!!
Each planetary gear inside your AT has a wet clutch pack and a brake sleeve that are wearable components. As they wear the debris washes through the transmission and eventually catches in the filter. All hydraulic fluid breaks down from use especially from heat while under a heavy load. A drain/fill removes particles as well as replaced worn fluid. Nearly all transmission failures and problems are simply from not servicing the thing on interval. It's a big expensive component when it does go out .
Old Feb 7, 2018 | 12:51 PM
No way that is from fresh fluid. I could bet money that it's because he didn't put enough fluid back in or put in the wrong fluid
Old Feb 7, 2018 | 12:54 PM
cleric670's Avatar
BANNED!!!
Telcoman
If you do the procedure correctly you will not have an issue.
People skip a tooth on timing chain replacements all the time. Is that the timing chains fault or the person who did the work?
twin001
71
Apr 21, 2015 08:16 PM
Nissan420sx
Sep 4, 2014 07:47 AM
ITSAGTHING
Drivetrain
18
Oct 25, 2009 07:09 PM
Heero
Jul 6, 2009 11:56 PM
chester
Mar 1, 2007 05:11 PM
