Tcm p1757
Old Dec 15, 2018 | 09:42 PM
rayj's Avatar
M35x
Tcm p1757
Hey guys,
I got a p1757 code, so I pulled the valve body and had the front brake solenoid connection fixed. Put everything back together and couldn’t get to move in drive or reverse any ideas?
Old Dec 16, 2018 | 07:50 AM
telcoman's Avatar
Veteran: Army
Originally Posted by rayj
Hey guys,
......had the front brake solenoid connection fixed
Fixed?
No year, no model and you expect assistance?
Read the FSM and follow the troubleshooting steps
Or
Just keep replacing parts and hope you'll eventually find the problem?
Possible cause 1757 FR BRAKE SOLENOID 6th• Normal voltage not applied to solenoid due to cut line, short, or the like.
•TCM detects as irregular by comparing target value with monitor value.
• Harness or connectors(Solenoid circuit is open or shorted.)
• Front brake solenoid valve
Telcoman
Old Dec 16, 2018 | 03:28 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
My guess is you didn't get something electrical plugged in correctly. Take apart the transmission harness(es) and inspect them for bent pins or any obvious damage.
NationsMostWanted
Dec 13, 2018 07:57 PM
NationsMostWanted
V36 Engine, Exhaust, Drivetrain & FI
Dec 13, 2018 07:55 PM
nazc0
May 5, 2014 02:04 AM
suprhulk
Drivetrain
Aug 11, 2003 03:26 PM
