AWD not working?
Old Feb 11, 2019 | 10:41 PM
Derek12's Avatar
07 G35X sedan with the HR and 5speed automatic
AWD not working?
I have a 07 X and the AWD doesnt seem to work, even in snow mode from a stop it only spins the rear. All fuses are good and no lights are on except for a TPMS light. Also sometimes when I want to have fun I'll turn off the VDC and do some doughnuts and drifts or whatever and sometimes the AWD light will blink fast then turn off after a minute or so. Any ideas on why?
Old Feb 12, 2019 | 03:16 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Get it scanned for hidden codes.
Old Feb 12, 2019 | 04:02 PM
Derek12's Avatar
will do
Old Nov 27, 2019 | 10:38 PM
Tylertu29's Avatar
G35
Awd not working
Did you ever figure this out ? I have a bad rear wheel bearing and the front tires are 225/50r17
and the back tires are 225/55/r17 I only have a Tpms light and sometimes the awd light flashes if I’m stuck but only the back tire spins could the mismatched tires cause the awd not to engage ? I’m sure the previous owner had the cr towed with the front wheels down so I’m hoping they didn’t mess it up
Old Nov 27, 2019 | 10:39 PM
Tylertu29's Avatar
G35
I need your help with this topic
Old Oct 19, 2020 | 04:07 PM
Tuner357's Avatar
Hey man, did you end up getting your vehicle scanned? Was it the solenoid inside the transfercase?
Old Dec 31, 2025 | 02:47 PM
qlskipper's Avatar
Same exact problem. 08 g35x, no lights on dash, exact same symptoms. Any luck?
Old Jan 30, 2026 | 06:28 PM
qlskipper's Avatar
Coming back to this, im still diagnosing my problem. Your tires have to be equal diameter or very close all around because the AWD system is very sensitive to the differences, and will disengage to protect itself. That’s what the dealer told me, and I do have uneven tread. I’m getting new tires and will keep updated
Karran Dhanroop
Feb 17, 2015 11:57 AM
brohar
Sep 12, 2011 10:04 PM
350GT-R
Dec 23, 2009 05:26 PM
stevoo74
Apr 1, 2008 10:59 AM
Ripmaster
Nov 27, 2007 02:14 PM
