2007 G35 sedan auto: 370z auto rearend fit???
Old Oct 2, 2021 | 06:53 PM
Realtor's Avatar
Hello,
I was hoping someone could confirm this will fit?
I am 99 percent sure but wanted to make sure with the community.
I have a 2007 auto g35 sedan with the oem 3.69 rearend.
I wanted to know if a 370 z auto rearend will bolt right in?
thanks
Old Oct 2, 2021 | 08:00 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You might have to swap the pinion flange (driveshaft flange). Look if you have a 3 bolt or a 4 bolt, the newer 370Z flange is a 4 bolt, if you have the 4 bolt flange it will bolt right in no mods. Otherwise you swap the pinion flange from the existing diff to the new diff. I think only the early G35/350Z came with the 3 bolt flange though so you SHOULD be fine.
If you need to swap the pinion flange don't know how to tear apart a differential plan on having a local shop do it so the preload is set correctly.
The only other difference is sometimes the bolts on the CV axle flanges, most use a bolt+nut, some used a thread flange. You can order new axle bolts from Nissan if you end up with the wrong ones.
Vir2L
Drivetrain
33
Jun 15, 2011 01:32 AM
welery
Media Share V36 Sedan
Jun 22, 2010 11:44 AM
Sportcoupe35
Jan 16, 2007 07:27 AM
medgar
Oct 30, 2006 07:00 PM
