does my 2007 G35 Coupe Base AT have a one plug or three plug transmission?
Old Nov 3, 2021 | 03:25 PM
sinina2007's Avatar
2007 G35 Base Coupe with Automatic Transmission
I am looking at replacing my transmission with a low miles JDM transmission. I'm not sure if the one on this currently has one plug, or three plugs. We're pretty sure it's one. Based on the info below would anyone be able to confirm. Trying to avoid putting the car up on the lift again if I can/
See Specs below
Infiniti G35 VIN Decoder
2007 INFINITI G35 Coupe 2dr Auto
Summary Style & Trim Equipment Colors Tech Specs
Narrow Down By Style 2dr Auto
General Information
MFR Model Code99217Body Type2dr CarPass Doors2Alternative NameCoupeAlternative Body2dr CarDrivetrainRear Wheel Drive
Mechanical & Powertrain
3.5L DOHC SMPI 24-valve V6 aluminum engine
Continuously variable valve timing control system
5-speed automatic transmission w/OD, learning algorithm, manual shift mode & downshift rev-matching
Rear wheel drive
Direct ignition w/platinum-tipped spark plugs
Advanced front midship platform
Independent aluminum-alloy multi-link front/rear suspension
Front/rear stabilizer bars
4-wheel vented pwr disc brakes
Dual chrome exhaust finishers
Engine & Powertrain
TypeV6 Cylinder EngineDisplacement L/CI3.5/213Fuel TypeGasoline FuelHorsepower275.0 @ 6200Fuel Economy18.0 City / 25.0 Highway MPGFuel Capacity20.0 galNet Torque268.0 @ 4800
Tech Specs
Manufactured ByJapan Infiniti Passenger CarSuspension Type - FrontMulti-Link Suspension Type - RearMulti-Link Front Tire SizeP225/45WR18, P225/40YR19, P225/50VR17 Rear Tire SizeP245/45WR18, P245/40YR19, P235/50VR17 Brake ABS System4-Wheel Front Brake Rotor Diam x Thickness12.6 x 1.1 in Rear Brake Rotor Diam x Thickness12.1 x 0.6 in Wheelbase112.2 in 112.2 min 112.2 max
Old Nov 3, 2021 | 10:32 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
'07 should be a single plug but just poke your head under the car on the driver side and look, doesn't need to be on a lift.
If your head is too big use your smartphone camera video and wave your arm around by the transmission.
Old Dec 25, 2025 | 11:10 AM
Dereckert's Avatar
If it helps, another way to narrow down your search without going under the car is to check the VIN in parts catalogs.
QuadCam
Jun 30, 2020 03:35 AM
Bmurphy380
Feb 3, 2017 09:56 AM
SweetThuy
Jul 5, 2016 02:35 PM
Jeremy1607
May 21, 2014 03:25 AM
