The good ol p0300!!??? Misfire and does if let off throttle??
Mar 6, 2022 | 09:35 AM
Start by getting all the bolts for the plenum, yes that can definitely cause a big vacuum leak.
Reply 0
Mar 6, 2022 | 01:02 PM
Plenum spacer install.
I ordered my 1/2 plenum spacer soo everything should be good to go when that comes in my test pipes are also on the way and I already received my headers and bigger injectors for the e85 tune later. I think once the plenum is tightened down she will run like a charm ready for her tune. My next purchase is my fuel pump then continue to make her pretty.
Reply 0
Mar 7, 2022 | 10:31 AM
Yoo thank you shes running
Quote: Start by getting all the bolts for the plenum, yes that can definitely cause a big vacuum leak.
it was definitely the vacuum leak i got the bolts from the junkyard real quick bolted the plenum nice and tight broke the mid plenum nut in the process which sucks *** but ill fix that I noticed the oil catch can breather breathing soo im hoping that means thats working I hope that wouldn't cause a vaccume leak too ill post up a video bro but thank you for being here thru this process and remember anyone who sees this thread check for vaccume leaks always eveeytime you remove **** check for a vac leak if your getting p0300 and just that code.
Reply 0
Mar 7, 2022 | 01:13 PM
Reply 0
