Release bearing stuck on shaft in transmission
Old Jan 22, 2023 | 06:04 PM
Supraguy31's Avatar
Veteran: Army
Coupe, Stock
So my release bearing went out yesterday. So I dropped the tranny, removed the wire clip between the fork and the release bearing, grab the bearing and try to remove it and it will only slide up the shaft about a inch or so then stop. I've tried everything I can think of to get it to slide off. I'm going to assume it's the original release bearing.
Any idea what I can do to get it to come off so I can get the new bearing installed and back in.
Thanks all
Robert
Old Jan 23, 2023 | 10:39 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Use a wire brush to clean all the splines thoroughly, then add some kind of grease, preferably moly since it needs to be greased again on reassembly. You might need to slide hammer it off but you should be able to just keep working it back and forth on the shaft and occasionally using that wire brush again to eventually get the bearing off.
Old Jan 23, 2023 | 10:43 AM
cleric670's Avatar
BANNED!!!
I should have specified BRASS wire brush, not steel.
Here is what it looks like with TO bearing removed.
Old Jan 23, 2023 | 12:04 PM
Urbanengineer's Avatar
Probably just clutch material built up on the input shaft or splines.
Old Jan 23, 2023 | 01:08 PM
Supraguy31's Avatar
Veteran: Army
Coupe, Stock
Going out now to see what I can do. I'm sure it's a lot of build up. Wife burnt the clutch disc out about 2 years ago and I should have just replaced it then. Bearing literally fell aparts when I slide the transmission back.
Old Jan 23, 2023 | 02:28 PM
Supraguy31's Avatar
Veteran: Army
Coupe, Stock
Thanks a million u all.
So after looking at the end of the shaft I noticed that there was a small lip where the sleeve was hitting. I took a file and filed the end of the shaft and the bearing came off. I want to thank u all for your assistance. She is back up and running.
g35life
Drivetrain
Mar 16, 2018 08:34 PM
socalg35x
Oct 10, 2017 03:19 PM
Mustang5L5
Oct 14, 2013 10:07 AM
fatlip
Mar 2, 2012 06:32 AM
Joaquin03
Jan 17, 2011 08:44 PM
