Clutch Noise when Idling. Goes away when clutch pedal pressed
Old May 28, 2023 | 02:29 AM
kgsunga's Avatar
G35 Coupe
Exclamation Clutch Noise when Idling. Goes away when clutch pedal pressed
I NEED HELP. So when the car is running and is idle, there's a knocking noise, but i know its not really a knocking noise on the engine, the noise disappears when I press my clutch in so its something with the clutch and transmission. Has anyone else had this issue? Please if someone has any knowledge of this, it would be appreciated. There is a noise when idling and the "knocking" noise disappears when I press down the clutch. Thank you
Old May 28, 2023 | 09:00 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Make a video of the sound and post it to youtube, then put the link here.
It's likely a worn out OEM flywheel / pressure plate / throwout bearing though.
G35-R
Mar 15, 2010 11:55 PM
red03g35
Apr 5, 2007 02:02 PM
basus
Nov 17, 2005 07:16 PM
