New member - introduction and request for technical info
Old Nov 5, 2025 | 01:50 AM
Vic in Illinois's Avatar
Hello all. This is my first post.
This spring I purchased an '03 G35 coupe through Fb Marketplace. It was owned by a young guy & has a decent number of minor modifications. However, it was disclosed right in the listing that it had a problem with the throttle body & the motor would not really rev more than a few hundred RPM above idle. The price was right, the car looked good, and I've wanted one for a long time. I checked it out & it started right up, sounded good, and when I put it in drive or reverse it engaged smoothly and would move forward and back, but as the ad stated, it would not respond to the throttle pedal.
I'm not a mechanic, but have one that has done great work for me previously and he said it sounded like a puzzle he would enjoy solving, so I had the car flatbedded to him. He has a full-time job & has been working on it occasionally in his spare time, but it's been many months with next to no progress.
Here are the codes he told me he was getting: U1001 , P1122 , P1126 , P0031 , P0051
This was how he described what he was able to find searching those codes & his results:
Low voltage at the throttle body on the line that is power from the ECM to the throttle body.
OBD scanner reading powertrain control module says low voltage, but digital multi-meter says there IS power to it.
G35 throttle body voltage - (at JustAnswer.com)
He could see a partial answer showing something about grounding one pin out to bypass the ECM's control of it, but the rest is hidden behind a paywall.
He needs someone to tell him what the voltage &/or ground should be with the vehicle off & with it running, going through the ECM to the input plug at the throttle body.
He needs a wiring diagram/schematic of the throttle body plug-in
It could be a bad wire, but he doesn't think so.
Does anyone here have the wiring diagram/schematic of the throttle body plug-in that they can share with me to give to him?
Please let me know if you have had this issue and, if so, how you were able to resolve it. I welcome any suggestions even if you haven't had this exact problem.
I trust my mechanic/friend, but am almost desperate at this point. I bought the car 9 months ago and haven't been able to use it at all. The car is in Kankakee, IL, so if anyone here is in the area and thinks they could solve the problem, please reach out to me.
Thank you.
Old Nov 5, 2025 | 11:08 AM
G2B35AGN's Avatar
You can download the factory service manual (FSM) at nicoclub.com.
https://www.nicoclub.com/archives/us...-database.html
That will have the troubleshooting sequence and datapoints you need.
03XG35
Feb 7, 2017 07:02 PM
immy_a33
Apr 29, 2013 11:57 PM
hashrock
Dec 7, 2012 11:21 AM
kingrukus
Jun 16, 2008 08:38 PM
RockG
Jan 9, 2006 02:22 AM
