Tranny Gear Ratios.
Old May 27, 2003 | 09:00 AM
Msedanman's Avatar
O.F. Administrator
Re: Tranny Gear Ratios.
That's right bro. The higher the #, the higher the multiplication > higher rpm's > faster acceleration.
but < top speed, and < mpg's.
<font color=green>GSM</font color=green>
Old May 27, 2003 | 05:57 PM
below's Avatar
I would venture to guess that you could change the rear end gear to accomodate your desires.....If they even make such a ring gear and pinion set for this car---if it even uses that simple design....I am not sure it if does, but most rear wheel drive cars do.
The higher the ratio the quicker you will get to top speed.
The lower the ratio, the more top speed you will get, thus dropping the rpms down for your mileage considerations.
&lt;p&gt;
hehehehehehehehehehe
Old May 30, 2003 | 09:39 PM
DC_G35's Avatar
Does anyone know the model number of the Coupe 5AT and what other vehicles it is used in?
Dave
03 G35 Coupe, Black/Graphite, 5AT
Old May 31, 2003 | 10:04 AM
Msedanman's Avatar
O.F. Administrator
According to my ESM, the model # is: RE5RO5A .. Don't know if the O is a letter or number.
Appart from the Sedan, I believe the same tranny is used in the 'Q'. Not sure if the new Max has the same one too.
seagrasser
May 3, 2022 09:43 AM
alessandro
Oct 8, 2015 09:29 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
DRG35R
Sep 16, 2015 05:33 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
