Is Castrol Multivehicle ATF oil safe?
Old Apr 1, 2006 | 02:43 AM
scorcher76's Avatar
Hey guys, my local Penzoil shop says that will use Castrol MultiVehicle ATF transmission oil for my transmission flush. Is this product equivalent to Nissan J-Matic (it does say so on the back of the bottle though...) or should I strickly stick with Nissan J-Matic at my dealership?
Scorcher
G35Sedan, '03 5AT
Old Apr 1, 2006 | 11:24 AM
Motown_Hog's Avatar
You can go with the non-OEM oil as long as it is the same grade. Trust me, I work at an OEM automaker and the aftermarket stuff is the same quality.
Old Apr 1, 2006 | 11:41 AM
ballisticus's Avatar
Looks like it will be OK
http://www.castrol.com/liveassets/bp...ehicle_ATF.pdf
but I would verify with the dealership the next time you are in the area just to be sure. It would be expensive to say the least if it isnt.
jeffbdye
Jun 1, 2018 03:51 PM
f22raptor
Mar 18, 2016 08:50 AM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
