Downshifting with Tiptronic
Old Sep 7, 2002 | 01:05 AM
Viper's Avatar
The manual shift gate (Tiptronic) does not seem to be a very good substitute for a stick, especially for downshifting.
If my RPMs are too high (for the computer) it won't downshift when I tell it to. Downshifting is not always smooth. Downshifting from second to first is very harsh unless I am stopped or going no more than a couple mph or so.
Is this the way it is supposed to be?
(Don't tell me to get the coupe, my wife wouldn't let me!)
Old May 4, 2012 | 10:08 PM
dukehotty's Avatar
You will get better with more practice.
Old May 4, 2012 | 10:52 PM
DailyDrivenCoupe's Avatar
Fail
Old May 4, 2012 | 10:54 PM
06PlatinumG's Avatar
Originally Posted by Nuckle
It is not very good for downshifting at all. However, You will get better at it after a while. The manumatic is really only good for sqeezing out a few more RPM per shift and leaving it in a low gear to play in the twisties.
I would disagree, I drive my car at the track all the time in manual mode. I works fine but there are a couple of things to remember. First I don't see a reason for ever going all the way back down to first and your right you have to be almost at a stop but the other gears the downshift will work fine if your coasting or braking. It will not downshift if you are on the throttle or if you are going to over rev the engine. So it's all about getting your timing right. I just posted a video (under motorsports) from the track a couple of weekends ago, watch it and listen to the downshifts.
Old May 4, 2012 | 11:27 PM
thescreensavers's Avatar
Mr.202?
threads from 02 bro
Old May 4, 2012 | 11:29 PM
herrschaft's Avatar
I see we're back to reviving pointless threads again.....
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Albanian122
Sep 12, 2015 04:02 PM
FRUG35
Sep 11, 2015 03:07 PM
FRUG35
Aug 31, 2015 02:33 PM
bdnbfrank
Aug 17, 2015 02:09 PM
