FS: 2003 VQ35DE engine Part out
parting out my 03 G35 DE engine NON REV had 150K miles on it prices don't include shipping LOCATED IN RALEIGH NC OEM steering Wheel throttle body $35 Water pump $35 Wiring harness $180 Valve covers R&L $60 each Thermostat $45 Heads $130 each Block $175 Sparkplugs $50 for all 6 Crank sensor $30 Camshaft sensors $50 both or 30 each Brand new never installed because had to replace the whole new engine Knock sensor $25.00 Fuel rails $100 Fuel injectors and harness $70 Pistons $80 all Rods $50 all 6 Coil packs $10 each Oem headers $35 each Cams $150 all Timing chain cover front and rear cover $115 each Upper plenum $100 lower plenum (MREV1) $80 Lower collector $60 Crank pulley $30 2 idle pulleys and brackets $40 each heat shields $10 each tensioner pulley $25 cam covers $60 each VTC Housing $60 each main wiring harness $100 o2 sensor $10 timing chain tensioner $20 coolant pipes $150 all Alt Bracket $15.00 wit screws Please make me offers i have all screws and nuts bolts ETC make me offers ill post more Pictures have more parts also just don't know the names lol thanks Kevin
Everything has been sold local only things I have left are crank pulley and rear timing covet
parts
joedaddy1
Jul 28, 2015 02:58 PM
