DIY: Spark plug change
#61
#63
Bump for a great DIY! Had the picts on pg. 1 printed out w/ the instructions and also watched the Youtube vid's posted in here beforehand. Took me longer than 2 hours, but I also cleaned my engine bay quite a bit since I had all those parts out...was able to clean up & wipe down hoses, Gordgee's grounding wires, covers, intake and tube w/ Simple Green...in dire need of it after the long winter of road salt & sand that made it's way into the engine bay.
Thanks all who contributed to this! You save me a lot of $.
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
#65
https://g35driver.com/forums/engine-...your-door.html
#68
Anyone know where I can find a relatively inexpensive torque wrench in inch-lbs? I have a ft-lbs torque wrench from Harbor Freight for $14. I know I can just do 95 in-lbs / 12 = ~8 ft-lbs but my torque wrench goes from 0-80 ft-lbs and it is probably not accurate in the lower range.
I don't think you need to worry...the 95 in-lbs is for the coil packs (not the plugs), I tightened my coil packs by hand until snug, just don't overtighten. My torque wrench is a 1/2" Craftsman Beam torque wrench from Sears, 0-150 ft-lbs, and for the 20-ft. lbs it worked like a charm.
#71
on
All in all, it took me 2 hours to finish the whole thing, which included reading the instructions and putting that anti-seize lubricant. I can probably do it in an hour next time.
P.S. My $17 torque wrench from Harbor Freight worked great.
#72
on
Question, I mishandled one of the plugs while I was inserting it back into the cylinder, and it slipped. I didn't drop it onto the floor or anything. It just slit off my fingers and tapped the engine slightly. It probably dropped ~1.5-2" or so. I checked and wiped the electrode and it looked fine. The car runs fine though.
Should I be concerned or am I just being paranoid?
#75
Yep. My 5/8" spark plug socket worked fine. The only issue I had was that my spark plug socket was barely "holding" the spark plug. It was slipping very easily. I had to use a magnetic pick-up tool to get the old spark plug out, which was pretty easy. I'll buy a magnetic spark plug socket next.
