DIY coolant bypass mod
Old Mar 12, 2009 | 05:19 PM
rpm06g35's Avatar
Well after several attempts to sell these things I realized it would probably be better for me to share the information rather than trying to sell and ship these things. I will only fab for local people as to be able to do the install myself. Burping of the coolant system is not an easy task. I really dont want to be responsible for someone messing up thier own car across the country. Enclosed are several pics with narations along the way. Any questions feel free to pm me. mike
full kit
driver side flange to block
driver side pipe bottom
passenger side pipe top
passenger side heater core nipple
rear cast pipe plugged
Old Mar 12, 2009 | 05:31 PM
rpm06g35's Avatar
Now for the pressure testing set up.
heater core nipple hose plug
passenger side front (to radiator) plug
driver side blank flanged off
driver side hose w air fitting
driver side ready for pressure check
cast manifold w/ convertion for air (through temp bung)
cast manifold blank flanged off
rear and passenger side ready for pressure check
guage setup w/ valve
Old May 9, 2009 | 11:32 PM
pwebb's Avatar
seems like a bit much for what seems like minimal gains.
anybody have any temperature #'s logged before and after this kind of modification?
looks fancy though. looks like something off my furnace...
Old Jul 21, 2009 | 01:39 PM
sexyrob's Avatar
great work man, what exactly is this by-passing? looks like the intake manifold lines and... something else.
Old Jul 21, 2009 | 01:50 PM
GreenGoblin's Avatar
The goblin resurrection
It gets rid of the factory coolant tube that runs across the front timing cover along with all of the smaller heating hoses to the TB and factory sandwich plate.
Old Jul 21, 2009 | 02:11 PM
sexyrob's Avatar
hmmm thought you needed the one that goes in front of the timing cover...
nvm, just did some research guess you don't need it.
Old Jul 22, 2009 | 05:06 AM
Andrei's Avatar
I think some people would have no problem installing it themselves. How much do you want for it? DM2 also sells one for $350 or so.
Old Jul 22, 2009 | 02:08 PM
The install is not super complicated but It is more difficult on auto trans cars to get the rear most pipe off the heads... Also bleeding the coolant system in these cars can be quite the challenge. Mike and I have got pretty efficient in bleeding them.
Andrei not sure when you say hoe much do you want for it... This is the same setup as the DM2.
Old Jul 25, 2009 | 09:19 PM
rpm06g35's Avatar
wow back from the dead?
Old Jul 25, 2009 | 11:33 PM
sexyrob's Avatar
yeah my bad... not that old though.
hey, I'll probably try this but if It doesn't work can I send the pipes to you for welding?
Old Jul 26, 2009 | 04:56 AM
rpm06g35's Avatar
sure thing bro no problem. we will work on a price then. Let me know mike
Old Jul 26, 2009 | 08:09 AM
Andrei's Avatar
PM me a price with the pipes included and shipping. 30046
I'm surprised nobody showed interest especially everyone who is FI. It's worth getting rid of the clutter let alone 10 degrees. At least the motor wont feel heat soaked like it does every day this summer.
Old Jul 26, 2009 | 08:22 AM
Andrei's Avatar
Original thread for anyone else looking.
https://g35driver.com/forums/forced-...otorsport.html
And the pipes are here.
Old Jul 26, 2009 | 09:45 PM
DRE's Avatar
DRE
oh we have the same name lol
Old Jul 26, 2009 | 09:59 PM
sexyrob's Avatar
btw are those pipes powder coated or just painted... do they get hot enough to boil paint?
