DIY: Manual Tranny and Diff Fluid Change
Old Jul 13, 2004 | 07:22 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
Re: DIY: Manual Tranny and Diff Fluid Change
service manual says 23-28 ft-lb for all drain and fill plugs
Golden Gate G35 Club
Old Jul 13, 2004 | 09:04 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
dklau33 ...
Great post. , the pics are great.
<font color=blue>04 Silverstone G35, 5AT, Prem, Aero
ES100 225/45-18 front 245/40-18 rear
Borla TD, Z-tube, Eibach, 35%Tints</font color=blue>
Old Jul 13, 2004 | 09:19 AM
jwg35c's Avatar
I understand the benefits of using synthetic in the engine. What are the benefits in the tranny and diff. ? I may switch when the time comes.
Jeff
Old Jul 13, 2004 | 10:08 AM
redwillow's Avatar
20 Year Member
that is a great write up. Notice any difference in driving after the fluid changes?
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, limo tint, Phatbox 40g mp3 player
Old Jul 13, 2004 | 11:30 AM
dbarnes's Avatar
NismoV35:
Saw where you changed out your tranny fluid with synthetic. Assume you have a 6MT? (your signature line doesn't say).
What synthetic did you use? How long has it been in, and did you notice any difference in the shifting action of the tranny? I'm considering changing mine out at 7500 miles to Redline Synthetic, as I've had good success with this in the past, speeding up "slow" synchros and getting rid of the "notchy" feel, which my 6MT seems to have in spades.
Did you change your clutch out of necessity (worn out), or for better performance? What effect has the Nismo clutch had? Did you have a factory viscuous LSD, and if so, have you swapped it out?
Don't mean to hijack this excellent DIY thread, PM me back if you want - it's just that guys like you, who have gone before some of the rest of us, can prevent us from "reinventing" the wheel.
Thanks.
Sport Sedan Fan - 2004 6MT Sedan
Sport/Navigation/Premium/Aero; "Invisiguard" Bra, Madico Onyx Tint
Obsidian Black/Graphite & "Titanium"
SHE'S SILVER & BLACK - GO RAIDERS!
Old Jul 13, 2004 | 12:15 PM
afr0puff's Avatar
Supa Dupa Moderator
Do NOT use redline synthetic for your tranny. Many Z owners have had their warranty voided because of this. The only accepted transmission oil accepted are Nissan, Amsoil, and I believe Castrol Transmax. Consult with your local service department first.
http://www.anythingbox.net
Old Jul 13, 2004 | 01:20 PM
dbarnes's Avatar
Thanks for the response, afrOpuff.
I wonder how they can exclude any manual transmission fluid that meets API GL-4 74w-85w or 75w-90w specs ??
Not saying they aren't voiding warranties, just wondering how?
Anybody have any insights or personal experiences to relate ??
Old Jul 13, 2004 | 02:22 PM
dklau33's Avatar
Neffster, you are correct. I should have been more specific and say 25 ft-lbs. I guess I was unconciously being lazy and assume everyone would know torque is measured in ft-lbs. Thanks for the catch.
Ah snaps, I can't edit my posts because time has expired on editing. Can a mod change the references of 25 lbs to 25 ft-lbs in the DIY steps? Thanks.
04' G35S 6MT Ivory Pearl, Willow, Premium
Z-Tube / NFC Y-Pipe / Custom Mid-Pipe / 350 EVO Rear Sway<P ID="edit"><FONT class="small"><EM>Edited by dklau33 on 07/13/04 11:23 AM.</EM></FONT></P>
Old Jul 13, 2004 | 02:28 PM
dklau33's Avatar
Yeah, the Redline MT-90 clearly meets the specifications put forth in the Service Manual and Owners Manual. I don't see how Infiniti can clearly void warranties on that. If it was Redline MTL then yes, I can see that happening since MTL is 70W-80 and not under spec. But MT-90 should be just fine.
Old Jul 13, 2004 | 05:19 PM
dklau33's Avatar
Shouldn't this be over in the DIY/FAQ forum by now? =D
Old Jul 13, 2004 | 06:35 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
dbarnes,
yes i do have the 6MT. I don't know which synthetic was used. I had the work done by Blast racing service they are one of the top 5 tuners from Japan. E-mail address: blastracing@sbcglobal.net I've had the Clutch in since Friday, Yes It Defitenly Shifts better MUCH smoother. Less notchy. I changed out the Clutch because the Stock Clutch could not handel the repeated Abuse from running a 100 shot of NOS. The stock clutch was pretty badly Glazed and the Flywheel was warped and Glazed Real Bad on 3 spots. The Nismo is rated for 400 BHP so it should handel my application just fine. Pedal Pressure is More Stiff, Takes more effort to push down, Springs back much faster and easier though. However It's Much more drivable than using the 4 Puck racing clutch from ACT. My friend is using the Nismo also on his 6MT sedan he also is using a Lightened flywheel. The only Mod on his car is Z tube with JW popcharger. He aslo is happy with his setup.......... Good Luck with your mods
Better Living Through Chemistry, N20
CPV35 Driven BY David K, VQ35DEN Tuned By DR CHARLES
...........NismoCPV-35
Old Jul 13, 2004 | 08:46 PM
DED's Avatar
DED
Thanks dklau.
Good job.
2004 G35C 6MT Black. Killer.
Old Oct 4, 2004 | 06:58 PM
AirSplat's Avatar
WOW! Great job! This is something I've always wanted to do.
04 6MT Pearl
K&N Typhoon/Grounding Kit
Borla Headers/Cat Back Exhaust
Kinetix Plenum/Cats
Nismo Front Bumper/Side Skirts
Impul Rear Bumper/Spoiler
www.AirSplat.com -AirSoft Guns
Old Oct 5, 2004 | 12:57 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
thanks bro...I'll have to do this!
2 G or not 2 G, there's no question!
Old Oct 6, 2004 | 03:43 PM
  #30
dklau33's Avatar
No prob. Real easy job, almost easier than changing the engine oil.
Z-Tube / NFC Y-Pipe / Custom Mid-Pipe / 350 EVO Rear Sway/ '03 350Z Shocks and Springs
