...the break in!!!!
Old Jun 2, 2006 | 05:19 PM
sixthGear's Avatar
...the break in!!!!
got my G two Sundays ago... pretty much rode it hard from day one, 1330 miles later i just got verbally bitch slapped by a friend of mine, for not "breaking it in".... researched it on here a second ago..... oops!!!! ...my bad.... what are the implications of not doing this and can i just reset the ECU and start over????
Old Jun 2, 2006 | 05:41 PM
gary c's Avatar
Break in...........
I don't believe in the "break in" period! Drive your
car normal but not in excess. I drove mine home
from the dealership at night going 70mph for about
30miles. Changed oil and filter (mobil 1) at 1000
miles and never looked back....I don't use oil between
changes and my G runs great. This is not '50 Ford
technology, it's Nissan '06 high tec!
Old Jun 2, 2006 | 05:49 PM
ballisticus's Avatar
You did good. The key is to avoid "sustained" high load/RPM operation during the first 1000 miles. The engine could and should be allowed to experience full load/RPM early and often. Just allow a 5-10 minute rest/cooldown by driving normally between WOT runs. This will let the hotspots dissipate and not permanently change tolerances there. Change your oil/filter now to a good synthetic and you will have a happy motor.
Old Jun 2, 2006 | 09:01 PM
sixthGear's Avatar
thanks guys..... glad to hear that, because i tried reseting the ECU using the pedal method.....yeah... wasnt too succesful with that....!!!! appreciate it
Old Jun 2, 2006 | 11:16 PM
rcdash's Avatar
break in is a physical process. why are you trying to reset the ecu?
Old Jun 3, 2006 | 12:36 AM
sixthGear's Avatar
yea...no idea!!!! but i guess its too late to re-do the "physical" aspects... appreciate the help.... so u guys changed your oil after 1000 miles..... as aposed to the 3500 recommended???? any good synthetic oil....
Old Jun 3, 2006 | 12:52 AM
Yes, run it hard then change to Mobil 1 5W/30 or equivalent.
Old Jun 3, 2006 | 01:08 AM
sixthGear's Avatar
thnks man... appreciate it
Old Jun 6, 2006 | 03:30 PM
jawjaw's Avatar
Yeah, don't sweat it. I think break-in procedures were more important in the past but not so much today because of precise machinework. It doesn't hurt to baby the car a bit in the beginning but there are those that believe you should run it hard from the start. The only consistent agreement is avoid cruising at the same rpm for long distances.
Old Jun 10, 2006 | 09:13 PM
AuAltima3.5's Avatar
I have heard two schools of "break-in" thought:
1) Drive normally, but don't go over 4k. Stay away from long periods of continous RPM (aka highways)
2) Run the p!ss out of it. This will help the rings seat more quickly. Someone had done this on a dyno and said they were making 5-10hp more than another car that was broke in by method 1. It was on cz28.com I think, can't remember.
Old Jun 10, 2006 | 10:16 PM
w0ady's Avatar
fgc moderator
never heard of anyone hurting a g from either break-in method. dont sweat it.
Old Jun 11, 2006 | 04:59 PM
Msedanman's Avatar
O.F. Administrator
As long as you avoided steady speed and real hard abuse, you'll be fine.
C.
Old Jun 12, 2006 | 08:14 AM
SURFJ9009's Avatar
Question 300 miles from dealership to home
Well ya'll. I have a problem.
I will be picking up my car from the dealership next month and I have to drive it about 300 miles on the highway to get it home.
If running at a constant RPM for too long is not a good idea, what can I do?
Kind of seems stupid to ship it when I can do the drive in 4 hours. Should I just stop often at the rest area and drive it in like 8 hours instead?
Old Jun 12, 2006 | 08:42 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Just vary the speed up & down...don't stay at a fixed speed.
& don't use cruise control
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
ara777
Oct 25, 2017 01:45 PM
prinny
Nov 22, 2015 11:07 PM
toadfire
Sep 21, 2015 07:15 AM
