Best Mod for around $500?
Old Jun 30, 2006 | 07:33 PM
davemelo's Avatar
Smile
Awesome. Thanks guys, your responses have all been well appreciated.
So this is what im thinking= Stillen Ztube/ Mrev2/ Stillen swaybars =)
Is there anything in particular i need to look for when purchasing the Mrev2 besides a Core return for my OEM one..?
What do u get better response from Mrev2 or Spacer? Anyone dyno results?
Thanks fellas
Old Jun 30, 2006 | 07:38 PM
Dakkerz's Avatar
I dont remember which gets better response but I remember reading somewhere that both on there own make comparable gains. Theres an entire thread about mrev on nonrevup engine that explains a lot.
Old Jun 30, 2006 | 09:28 PM
GeeMan's Avatar
Originally Posted by davemelo
I already have a drop in K&N filter that replaced the Stock one, i just need the Z-Tube. I heard that the Injen cold air has some really nice sounds to it but also alot of complaints. I guess its all the vibrating from the length of the pipe?
Anyhow, i migh just clean my K&N Filter and get the stillen Ztube for around $50. Still taking advice if you guys got some =)
Or check on my350z.com for a Z person selling their z-tube. Skip the CAI unless you are only expecting a sound change and some bling. Really marginal gains, if any with a CAI. Your K&N drop in and stock intake are the best bang for the buck with addition of the z-tube.
With your budget, spacer and sway bars are the ticket.
Old Jul 3, 2006 | 09:25 PM
exagorazo's Avatar
Suspension Mods will give the biggest bang for your buck
Don't waste your $500 on engine, intake or exhaust mods. All of them COMBINED do very little. One $500 mod will not do anything noticable, unless it's noise you're after. The only power mods worth talking about involve FI.
In my experience, suspension mods will provide a far more tangible improvement than power mods. I installed Eiback sway bars, Eiback Prokit springs and Tokico D-spec shocks. You couldn't do the springs and shocks together for that budget, but if you could do the work yourself, you'd sorta be in tha ball park. It would be a shame to do only springs or only shocks since they share so much install labor. And they would provide a dramatic handling improvement. If you're tight on the $500, do just the sway bars. They make a nice improvement in cornering.
Old Jul 3, 2006 | 11:08 PM
rlwjr1's Avatar
Originally Posted by booger
... A plenum spacer may lean out the Drivers side of the motor to much
Originally Posted by Dakkers
Either a spacer or MREV2 is a nice bang for the buck engine mod. Wouldn't do both though (unless you plan on getting a tune) since the combination tends to run lean on non-revup engines.
I've asked this question before and here appears to be the reason for my confusion. Is MY car going to run lean with ONLY a spacer, it's a 2004 6MT Coupe.
Old Jul 4, 2006 | 02:18 AM
mistermojorizin's Avatar
i've ridden in an 03 6mt coupe with only 1/2" spacer and hks exhaust and it seemed to pull harder than stock. more so I would say than my car
although you guys are anti-intake, i read a post on 350z where the guy said that intake doesn't do much until you add a spacer. i'm thinking i'm gonna try a stillen intake and see how that is with mrev
Old Jul 4, 2006 | 03:49 PM
rlwjr1's Avatar
Charchar66
Dec 19, 2019 01:17 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
RWDguy4238
Sep 30, 2015 12:13 AM
