synthetic vs. non-synthetic
Old Jul 6, 2006 | 03:50 PM
kavehdr's Avatar
Hi could someone who "really knows" about the difference and has some knowledgable understanding explain the difference between these two oils and also recommand which one to use on a brand new G?
Thanks
Old Jul 6, 2006 | 04:04 PM
bwassul's Avatar
I don't know the difference in chemical makeup, but synthetic oils have been shown to lubricate better and last longer. As far as when to use synthetic, some say right away, but I think it's better to run the engine through a couple cycles of regular oil (~8k-10k miles) to let critical parts wear together normally.
Old Jul 6, 2006 | 04:07 PM
kavehdr's Avatar
I see. What do you exactly mean by letting the parts wear together?
Old Jul 6, 2006 | 04:12 PM
Jeff92se's Avatar
Red Card Crew
During your break in period, I'd use normal dino oil and short change the intervals.
either your dealer or your owner's manual will have this information.
Old Jul 6, 2006 | 04:50 PM
Rookie84's Avatar
For break-in, I would use dino oil and change it at 1000 miles. After that, one more period of dino oil for 3000 miles, and switch to synthetic FTW. That is what I would personally do if I were to get a brand new car.
Old Jul 6, 2006 | 05:19 PM
JackTsG35's Avatar
Here's some propaganda from Red Line Oil - Royal Purple has similar data - but the points about synthetic oil in general may be useful to you.
http://www.redlineoil.com/whitePaper/motoroils.pdf
Old Jul 7, 2006 | 12:56 AM
kavehdr's Avatar
what brand do you recommand?
Old Jul 7, 2006 | 01:16 AM
silver g's Avatar
I have heard that it does not matter based on the ways oil is produced nowadays. But regardless I still run synthetic. It makes me feel better.
Old Jul 7, 2006 | 01:20 AM
kavehdr's Avatar
so how often do you change? can you tell the dealer to put in synthetic or do you have to do it yourself? I also checked the Mobil website, they have 3 different kinds: a 5000, a 7500, and 15000 miles oil. The 15000 sounds ridiculous!! so you just change it and the next time you need to change is a year after!!!????
Old Jul 7, 2006 | 04:07 AM
UK-Nissan's Avatar
Bobistheoilguy.com for all the help you need on oil.
Mike
Old Jul 7, 2006 | 04:36 AM
Derek173's Avatar
I now run GC ( german Castrol 0w-30) Cause of that site
Mike
Old Jul 7, 2006 | 08:58 AM
rob40wilson03's Avatar
i cant find info on GC on bobistheoilguy.com, did you learn about it in a forum there..... and why did it convince you to use GC?
Old Jul 7, 2006 | 10:28 AM
jetblackg35's Avatar
I run Mobil 1 every 3500 miles
Old Jul 7, 2006 | 10:56 AM
1stG35inCTRY's Avatar
... I know in the states people change oil quite frequently... like every 3000mi and I don`t know what oil is used , but I always put synthetic oil in every car I have owned and change it every 6-7000mi... and I try not to forget to check the level AND the color of the oil... because sometimes it is usefule to change it when it IS needed and not when it is supposed to be changed... and the same is - if oil level is ok and oil is fresh... there is no need to change it, just because you dealer says it. and you know why they say it
