what is the stock size fuel injector?
Old 07-22-2006, 09:48 AM
QuadCam's Avatar
I have been looking and searching, but I can't find the answer.
Does anyone know. I couldn't even find the answer in the service manual.
Old 07-22-2006, 11:17 PM
Xman's Avatar
380cc.
On another topic , after install of a B&M Trans cooler ATF was leaking at the return lines. I double clamped and will be monitoring as you suggested. Thanks. If I had went to an event today I may have dumped another tranny.
Old 07-23-2006, 12:29 AM
timzcat's Avatar
Get a flaring tool and flare the metal line before putting the rubber line on.
It will prevent a hose blow off.
Old 01-10-2007, 02:29 PM
ma_sha1's Avatar
I read at 350Z.com that Z is 280 or 300cc dpends on years,
How come G is 380cc so much bigger than Z?
A prior thread someone daid it was 290cc:
https://g35driver.com/forums/showthr...light=injector
Old 01-10-2007, 11:14 PM
QuadCam's Avatar
essentially, it is a 290 cc/min injector rated at a 3bar fuel pressure.
Our cars run at a 3.5bar fuel pressure setting.....which effectively changes these to about a 330 cc/min.
Injector flow rates are proportional and relative to the fuel pressure.
marsman328
Northern California
08-11-2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
08-10-2015 07:04 PM
Cam_Cooper3
08-04-2015 01:53 PM
Quick Reply: what is the stock size fuel injector?
