60k service
Old Jul 26, 2006 | 12:41 PM
Redsun's Avatar
60k service
hey guys whats included in a 60k service?
Old Jul 26, 2006 | 02:08 PM
Back2VQ's Avatar
from my past experience, every dealership has their own "60K" service so it may vary depending on where you go, but typically they'll do transmission, differential, coolant, brake flush, throttle body cleaning, replace timing belts (for cars with belts), oil change, tire rotation, top off fluids, to name a few... i think they usually charge around $1k for the entire service. well worth it especially if you're gonna keep your car a while, but most of what they do, you can DIY.
Old Jul 27, 2006 | 12:23 PM
Q45tech's Avatar
It's your last major chance to suck up to dealer to pay them to find warranty items that Nissan can be persuaded to pay for............why 60k services should be done at 59,000 miles.
Old Jul 27, 2006 | 09:12 PM
dTor's Avatar
Look in your owner's manual.
Old Jul 28, 2006 | 01:55 PM
G35 Mass's Avatar
Service Manual Schedule of Periodic Maintance.
Note: this is schedule 2, normal driving. Hard wear and tear on the vehicle, uses schedule 1. The distance between services is effectively half of schedule 2, so this would be the 30k service.
Replace:
  • Air Cleaner Filter
  • In cabin micro filter
  • Engine coolant (after 60k, every 30k)
  • Engine Oil & filter
Inspect:
  • Drive belts (after 60k, every 15k)
  • EVAP vapor lines
  • Fuel Lines
  • Brake lines & cables
  • Brake pads & rotors
  • MT gear oil, ATF fluid, & differential gear oil (DEMANDS Nissan Type "J" for ATF, otherwise warranty voided)
  • Steering gear & linkage
  • Axle & suspension parts
  • Exaust system
Non-service items:
  • Fuel filter
Service when necessary:
  • Intake & exaust valves
After 60k, everything will have been serviced, except the spark plugs. They are repaced at 105k
Old Jul 30, 2006 | 09:43 AM
Q45tech's Avatar
The legal life of a vehicle is 100,000 miles, most are pretty trouble free to 150k [assumming higher than minimum maintenance] if you want 200k or 300,000 miles you must start early to change all lubricants and do things more frequently and better!
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
infinitiway
Aug 8, 2017 12:38 PM
f22raptor
Mar 18, 2016 08:50 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
