HorsePower!!!!!!
Originally Posted by Pauliejr
what will make it sound nicer i want a nice powerfull sounding car.
Like what most said...personally I have JWT popcharger/z-tube and 5/16" MD plenum spacer and it sounds very, very nice already. The spacer improved the air flow to the engine so my stock exhaust sounded louder...dont quote me on that I could be wrong, but my friends thought the exhuast sounded louder than before also.
Originally Posted by hai109
Give me 200 bucks and i'll sit in your car and make a growling noise to make it more aggressive...hahah
i do it for 100 plus ill make the bov sound when u shift (whoooosh).
Originally Posted by skaterbasist
Stillen Intake
Z-Tube
Plenum Spacer
Mrev2
Grounding Kit
UR Pulleys
Test Pipes
HKS or Stillen Exhaust
Stillen Headers
Cams
Vortech SC
It Might Cost you a little bit more than 200 though
Z-Tube
Plenum Spacer
Mrev2
Grounding Kit
UR Pulleys
Test Pipes
Stillen Headers
Cams
Vortech SC
what he said... but if you want, you can drill a hole in your exhaust
kidding.
In a NA vehicle already tuned by factory pretty well for magazine tests, each additional horsepower may cost $50 to $100 each.
Rear differntials have the highest friction losses at very low speeds and in cold weather so a synthetic diff lub can improve low speed [launch to 20 mph] rear wheel torque by 1-1.5% for just the price of the lub.
Conventional vs ethanolized fuel can provide higher BMEP [torque].
BG44k can clean injectors and deposits from valve stems and piston crowns.
Synthetic oils can reduce friction enough to increase power by 1-2 HP.
Unfortunately it takes a real [not promised] 10 lb/ft increase to be measurable in a reduced quarter mile time of 0.10 seconds.
Get a leaf blower Shold cost you even less then 200
http://videos.streetfire.net/search/...ad23ca9564.htm
Originally Posted by audiblemayhem
a Z tube and a KnN drop in filter would be what i would do with $200 dollars, then i would take $90 i had left over and buy me two hookers...
Or go to the strip club and get your socks blown off.!
Originally Posted by absolutg
that just means he's gonna fart really loudly... watch out
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
