View Poll Results: if I'm NOT running lean (non-revup)... (plz read below before voting)
MD 5/16" Iso Thermal spacers
30.00%
MREV2
16.00%
Combo of both
27
54.00%
Voters: 50. You may not vote on this poll
Spacer or Spacer/MREV2 combo?
Old Sep 6, 2006 | 08:04 PM
maxpower's Avatar
Originally Posted by andy2434
Yes, that is correct. The MD spacers will work just fine on the non RevUp engines. The spacer alone will afford little, if anything, on the RevUp engines.
I know it made a difference on my 05 AT (3/8" spacer + iso thermal)
Old Sep 6, 2006 | 08:26 PM
Andy2434's Avatar
The Motordyne plenum spacer was initially made for the Non RevUp engines. The same when installed on the newer RevUp engines dyno'd no improvement. Then Tony introduced the MREV , which was a spacer and a non RevUp lower collector combo . . . Soon, it was followed up with the MREV+, which was a spacer and a modified non RevUp lower collector combo. Now . . . there are the spacers and the MREV2. The spacers are still the same. However, the MREV2 is an even more modified version of the non RevUp lower collector. The original MREV set-up was originally sold as a combo package for the RevUp engines, which consisted of the lower collector and the spacer. Now, the spacers and the new MREV2 lower collector are sold separately. It's been made easier. You pick and choose your set-up.
Old Sep 6, 2006 | 10:58 PM
vt_maverick's Avatar
Guys, all G35's in 2003 were non-revup, regardless of tranny option.
Old Sep 7, 2006 | 12:13 AM
V35 Skyline GT's Avatar
6MT Coupe
Is that not true also for the 2004's?
Was it in 2005 the rev-up VQ was born with 6mt's only?
I think so, but not sure. This is why I'm asking for my educational knowledge.
Old Sep 7, 2006 | 12:23 AM
Yes, 2003 and 2004 were non-revup in both transmissions. And yes, 2005 was the first year of the rev-up.
Old Sep 7, 2006 | 12:36 AM
glennp_1999's Avatar
^^^ +1
Old Sep 7, 2006 | 12:51 AM
6MT Coupe
Thanx VT for confirming that.
Old Sep 7, 2006 | 01:57 PM
maxpower's Avatar
correct
05 AT = non rev
05 MT = rev up
Old Sep 7, 2006 | 11:36 PM
mark4x4's Avatar
Andy, with all these options what is the best set-up for a non revup engine. I'm assuming it would be the MREV2 only?
Old Sep 8, 2006 | 12:21 AM
6MT Coupe
Originally Posted by maxpower
correct
05 AT = non rev
05 MT = rev up
Thanx...that's what I thought.
Old Sep 9, 2006 | 08:35 PM
OCG35's Avatar
I don’t want to speak for Andy - but this question has been asked in many dif ways (I originally was inquiring when MD introduced MREV2).... the bottom line IMO is... the jury is out as far as combo. There has simply not been enough (practically no) data/stats to make an informed decision about the lower collector. However, I can tell you first-hand the spacer (I have 1/2") is definitely worth the purchase.
I would LOVE to see data regarding the MREV2 combo w/spacer (particularly 1/2"). There are several people that have been saying they will dyno but it's been months.
I'm thinking/hoping Nissan Sport Mag (formally Sport Z) will put the questions to rest... fingers crossed.
Old Dec 21, 2006 | 10:28 PM
s2k_g35's Avatar
so i have a 04 6MTcoupe. I can't do a combo?
I thought the MREV2 was for revup engine only.
If i get the 5/6 spacer and JWT pop charger would that run a lean?
or the MREV2+ 5/6 spacer + JWT pop charger will run lean?
I know the ECU flash going cost at least $1200 or more depend on shop.
Old Dec 22, 2006 | 12:05 AM
wilksoner's Avatar
im runnin gthis set up now on an 06 6mt and im very impressed with it this is the first ive heard of running lean and to be honest im also runniong headers and exhaust with it and intake and i have no probs of the such
Old Dec 22, 2006 | 12:29 AM
ballisticus's Avatar
I have the 1/2" spacer only, but I do have the NextGear thermal isolation between the lower plenum and final injector assy (bought before the MD Isotherm was available). I dynoed with this, Z-tube w/ KN, and the Stillen catback and my A/F was dead perfect at 13.1 and flat though the revs.
You should not be lean at all with just a spacer and JWT on an '04. Also, $1200 for reflash? I sent mine in to TS for the F-Spec + fuel optimize based on my dyno and it was $495.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
