RB26 Swap Project
Old Jan 22, 2007 | 07:01 PM
  #61
a13xkim's Avatar
this is one heck of a project... hope it goes well man!
Old Jan 22, 2007 | 10:27 PM
  #62
binder's Avatar
why is everyone concerned that the rb26 can handle 700hp on stock internals? why does that matter really? if you build 700hp on a vq and 700hp on an rb....it's still 700hp. Ya, you might have to beef up the vq from stock to handle it but it doesn't matter, it'll be still way cheaper and faster to do that.
and there are vq's putting over 750 to the ground.
like most said, i just don't see hte point in a brand new car...maybe something older as a pure sex sports car with no interior.
Old Jan 26, 2007 | 08:44 AM
  #63
Slick 6MT's Avatar
Thumbs up
Originally Posted by Blackedout05G35
Hey guys i know i havnt been updating you guys much i got the motor but im rebuilding it pistons, rods, and im going single turbo as well so the project is going to take a lil longer then expected ill post pics of the motor build =)
Sounds good! Whats the completion ETA?
Old Jan 26, 2007 | 11:18 AM
  #64
izmir41500's Avatar
G35driver Addict
where are the pics of the motor build?
Old Jan 26, 2007 | 11:37 AM
  #65
GreenGoblin's Avatar
The goblin resurrection
What shop is doing this
Old Feb 2, 2007 | 02:20 PM
  #66
Nismo G's Avatar
any up date on this project?
-sean
Old Feb 2, 2007 | 04:10 PM
  #67
brianyun's Avatar
i want to know too! update pics?
Old Feb 2, 2007 | 04:59 PM
  #68
fhumphrey04's Avatar
Not all 700hp cars are equal, some are much faster than others.
A 700hp LS1 will almost ALWAYS be faster than a 700hp 2JZ. The higher displacement of the engine allows for higher airflow to spin the turbos at lower rpms, not to mention the capabilities of the vette platform vs. a supra platform...but that is besides the point.
V6 engines never seem to be able to reliably produce the high hp compared to inline 6's either....but that might just be my observations, I dont know. If this guy is into show a RB powered g35 is much cooler than the usual vq too, so keep that in mind.
Old Feb 2, 2007 | 06:16 PM
  #69
binder's Avatar
that i could see
Old Feb 27, 2007 | 11:01 AM
  #70
b00stedjustin's Avatar
what? I don't agree at all with your assessment. When have you ever seen a non turbo 700 hp ls1? 700 hp supra's are a dime a dozen, so I don't know where you get off here. Also the RB is not a better platform than the vq. It's heavier, has less displacement (=more turbo lag) and if built properly, the vq could operform the RB all day (one of the reasons why the new gt-r is using a v6 tt setup). This is one of the reasons why the RB is not being used anymore, plus the fact that the RB even completely stock will not pass smog standards. For "show" you may be right, but the whole "show" thing has been rapidly dying off recently, (IMA), and frankly those whom would prase a g for an RB powerplant are only thinking of the old skyline and really care nothing for our cars.
Old Feb 27, 2007 | 11:23 AM
  #71
BadBoy06's Avatar
updated pics would be love love
Old Feb 27, 2007 | 11:27 AM
  #72
Jeff92se's Avatar
Red Card Crew
Read his statement again. Never said na 700hp LS1
I'd have to say from a pure strength standpoint, the RB is superior. The iron blocked I6 is ideal for high boost strength. The reason the RB series was discountinued was it's weight, age and long length. It doesn't does fit into many newer plateforms anymore. Nissan could make the RB pass emissions with modern CAN obd and new ecu.
Old Feb 27, 2007 | 12:57 PM
  #73
Kidcane's Avatar
^^Jeff, what does your signature mean, "SHOW YOUR SUPPORT TO BRING BACK (chad@infinitispecialists)! MEMBER #2"?
Old Feb 27, 2007 | 01:11 PM
  #74
Like Jeff said, I never mentioned NA, in fact I specifically mentioned the higher displacement of the motor allowing for more airflow to spin the turbos earlier.
Whether the RB is inferior to the VQ, I have no idea, I never said it was. The VQ cant run the high psi on the stock block like the RB can, but anyone debating between the two will have enough $$$ to build it anyways.
Old Feb 27, 2007 | 01:38 PM
  #75
g35brandon's Avatar
Wel it seems like an awesome project, however a TON of money will be involved...Good luck - I want to see it work out for you!
