Performance
Old Sep 21, 2006 | 03:32 AM
MattScott's Avatar
Performance
I have Nismo CAI, 5/16" Plenum spacer, Unorthodox pulley set, Megan Racing Headers, Invidia G200 exhaust, I was wondering what else could I do to my car performance wise, without spending more then $500 that would make a noticable diff? Anyone?
Old Sep 21, 2006 | 03:34 AM
anDross's Avatar
Test pipes or metallic resonated test pipes, high flow cats, yada yada
Old Sep 21, 2006 | 03:35 AM
anDross's Avatar
Fast Intentions is having a sale right now.. look into them, they have quality stuff, and they got the proof to back it up
Old Sep 21, 2006 | 03:59 AM
MattScott's Avatar
Will the testpipes set off my check engine light? Will HFC's set off my check engine light?
Old Sep 21, 2006 | 09:05 PM
techi13's Avatar
used light weight flywheel
thermo gaskets and the coolint valve thing-a-ma-jig (be able to close the coolint tube to heat your plenum)
Old Sep 22, 2006 | 02:19 AM
RebelinRI's Avatar
HFC's no .................... Test pipes Yup. But you can trick the car for real cheap so the pipes won't throw a code.
Old Sep 22, 2006 | 11:59 PM
dTor's Avatar
You already said it... diff.
If you have a 5AT, call Turbo Toys in Tampa, FL and get a 3.5 pumpkin for about $500 and swap it out. You will notice just as much if not more improvement in acceleration with just that than you did with all your other mods combined.
Or get an ECU reflash.
Old Sep 23, 2006 | 12:31 AM
MattScott's Avatar
pumpkin?
Old Sep 23, 2006 | 01:18 AM
dTor's Avatar
Yup... pumpkin. And I'm not talking about what you carve for halloween.
Do a search for final drive, pumpkin, gears, vlsd, or differential. There is a ton of info for you to learn what it is, how it works, and how it will benefit you.
Old Sep 23, 2006 | 02:26 AM
ChiefyMan's Avatar
Originally Posted by MattScott
pumpkin?
lol you and me both, man.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
prinny
Nov 22, 2015 11:07 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
